S2K Kpro + wideband problems
Posted: Fri Mar 09, 2012 1:52 pm
by 27psi???
OK i have kpro 3 in a 2005 s2k. I have a aem 4100 wide band that the guage is reading and im get the correct output one the white wire. I cannot get the ecu to read the output. I belive the eld i should be using is e15? but this spot is not working. I changed grounds and still nothing. The wire is a white cream color and bigger then the others is this the right one? in kpro i have the eld enabled and the aem 4100 selected on digital input but still get nothing. what am i missing?
Re: S2K Kpro + wideband problems
Posted: Fri Mar 09, 2012 2:05 pm
http://www.hondata.com/s2kpinout.html
You have the wrong pin for a S2000.
Posted: Fri Mar 09, 2012 4:13 pm
by 27psi???
Spunkster wrote:http://www.hondata.com/s2kpinout.html
so then a30? its a black and white wire on the bottom right of the plug correct?
Posted: Fri Mar 09, 2012 4:20 pm
A30 is correct. We dont' go by color. Go by the actual pin position.
Posted: Mon Mar 12, 2012 3:51 am
by finalsection
Then disable the eld in the parameter.
Posted: Mon Mar 12, 2012 8:59 am
by 27psi???
ok so a30 is the pin i need and I tried the pin in some of the files that look like a30 but didnt work then (look at picture below) the A connetor plug reads at bottom left 32 - to bottom right 25 suggesting that the 3 wire from left would be a30. this also didnt work. any one with a s2k thats done this before please let me know whats wrong. and i disabled eld. sorry for huge photo
Posted: Mon Mar 12, 2012 9:52 am
Pinouts are read from the wire side, from the top, left to right with the clip at the top.
Posted: Mon Mar 12, 2012 10:42 am
by 27psi???
Spunkster wrote:Pinouts are read from the wire side, from the top, left to right with the clip at the top.
right which is what i thought reguardless of the numbers on the plug. now acording to the pic below it would be the 3 from the bottom right the green and red wire. I tried this also and it still not reading!
Posted: Mon Mar 12, 2012 11:10 am
Draw a diagram of exactly how you have everything wired.
