Acura TSX Hondata calibrations and immobilizer
Posted: Sat Mar 03, 2012 7:24 am
by Zoro2006
Just checked your base calibrations (for example with RDX 410cc inj.) for Acura TSX and found that all which has CAM agles 0 10 20 30 40 has immobilizer disabled flag. Uploading it to ECU Flashpro Pop-up warning that immo can't be disabled. Can you make all calibrations equal with immo enable by default.
Re: Acura TSX Hondata calibrations and immobilizer
Posted: Sat Mar 03, 2012 10:27 am
Already has been fixed.
Posted: Sat Mar 03, 2012 10:48 am
by Zoro2006
Hondata wrote:Already has been fixed.
today found one interesting error, all your default maps with 0 10 20 30 40 Cam angles can't go past VTC 20 degree, tried to enter in low and high VTC tables 30 and 40 degrees.
Posted: Sat Mar 03, 2012 3:41 pm
The standard VTC goes to 25 degrees. Some people replace the VTC with a RSX 50 degree version.
Posted: Sun Mar 04, 2012 1:02 am
by Zoro2006
Hondata wrote:The standard VTC goes to 25 degrees. Some people replace the VTC with a RSX 50 degree version.
I know that standard goes till 25 degree. In my car VTC is 50 degree and your standart calibrations with CAM agles 0 10 20 30 40 has bug, impossible to go more then 20 degree. Look in datalog and low VTC table.
Posted: Sun Mar 04, 2012 8:55 am
Yes, you're right, the cam angle seems limited to 20 degrees for some of the calibrations. The 2004-2005 base calibrations goes to 50.
Try out this calibration.
Posted: Sun Mar 04, 2012 9:29 am
by Zoro2006
Hondata wrote:Yes, you're right, the cam angle seems limited to 20 degrees for some of the calibrations. The 2004-2005 base calibrations goes to 50.
now it can go above 20 degrees, but I got VSA error in dash even it was checked in calibration and immobilizer still disabled.
