K20a2 Reflash w/ Cam Upgrade?
flea132435
Post by flea132435 »
I have the k20a2-4 ecu reflash, and I am thinking of upgrading my cams. I read that my reflash works well with ITR cams... are their any other cams that I could swap into my engine while maintaining my current ecu programming?
Re: K20a2 Reflash w/ Cam Upgrade?
There is a reflash for stock cams and another reflash for type r cams. For any other cams you should use the KPro.
stonjohn4
Post by stonjohn4 »
any idea where can i get 07 08 tsx manual trans computer i tried many dealers, junk yard and no body has it. the dealers are in backorder and no release date.
any idea please????????????
rl20zero1
Post by rl20zero1 »
Doesn't the 05-06 RSX-S have ITR cams? If so could I use them for the flash? What else would be needed to swap out the cam shafts or just the shafts themselves? Thanks!
