Turbo GSR basemap
Posted: Sat Feb 11, 2012 5:21 pm
by grunny
Gsr block
Eagle rods
wesico pistons 9 to 1 comp
B16 head ported with gsr cams
880cc injectors with injector box
stock map sensor for now
E85 fuel
I just need a base map to get the car running for the first time, will be trailer to the tuner.
Thanks in advance
Re: Turbo GSR basemap
Posted: Sun Feb 12, 2012 9:09 pm
by hpmx18
if you load a gsr basemap and add about 45% to the low cam fuel map the car will be a tad bit richer then normal but it'll get you to the tuner e85 is usually bout 30-45% more fuel i seen more on some instances depending on the setup
