DA K20 swap S2000 cluster wiring question
the sled
Post by the sled »
I recently got this K20A2 swap running in this '91 DA Integra using a '05 Z1 tranny and K-PRO. I used the Hybrid Racing converter box for the VSS signal using 02-04 harness/connecter/ECU, but with the 05 VSS sensor. Obviously since the DA is run by a cable speedo, i installed a AP1 S2000 cluster; the speedo does not work on the S2000 cluster. I still have the ECU as using a regular signal(not the countershaft one), am I right to assume that I just need to change the setting in the KManager, or do i need to get rid of the converter box and change the 12V signal to a 5V reference on the sensor?
the sled
Re: DA K20 swap S2000 cluster wiring question
Post by the sled »
I got it working, I took out the hybrid converter, put 5V reference to the sensor instead of 12V, and ran the cluster output signal(low frequency) to the ECU so that reads a correct signal as well, and left the ECU with the regular 02-04 setting.
This thread can be closed
