Counterfeit ECU
Posted: Fri Feb 10, 2012 5:47 pm
by bowman
So I went to upload a base map today and it failed.. Found out i have a counterfeit ecu.. Is there anyway I can get my car running a base map with the counterfeit kpro because I daily drive this car and cant afford the 750 for a replacement
Re: Counterfeit ECU
Posted: Fri Feb 10, 2012 6:22 pm
I think your only option is to remove the counterfeit board and see if it will run limited to 4000 rpm.
Re: Counterfeit ECU
Posted: Sat Feb 11, 2012 9:43 am
by bowman
You think it will run my car? the immobilizers are different and its a auto ecu
Re: Counterfeit ECU
Posted: Sat Feb 11, 2012 7:24 pm
It is has not run your vehicle previously without errors, then probably not.
