can we run the k pro with no high speed speedo signal
bigal
Post by bigal »
K-Pro .If we do not require a signal to drive a speedo can we run sucessfully with or without a signal from the high speed speedo drive using a low speed engine harness or do we need to swap out the harness as well.
Re: can we run the k pro with no high speed speedo signal
The 2002-2004 (low frequency) harness does use the same VSS connector as the 2005+ (high frequency) harness. Usually the easiest route is to use the 2002-2004 transmission case with vss.
Read the information in the tech section of the website: http://www.hondata.com/techk20transmissions.html
bigal
Post by bigal »
Spunkster wrote:Read the information in the tech section of the website: http://www.hondata.com/techk20transmissions.html
yes have been through all this
will kpro [using low speed engine harness] run ok without a speed sensor signal ?
ie connected but not being driven
will lack of speed sensor or speed sensor signal affect operation of vtec ?
You must have a properly functioning speed sensor signal going into the ECU.
