h22 1000cc e85 3bar
h22 1000cc e85 3bar
here ya go tha car made 600 but i retarded a good bit till you dyno for your setup
LGMotoring
IG:Lgmotoring_official
Lgmotoring.com
Lgmotoring.com
patroick67
Re: h22 1000cc e85 3bar
I am curious will this be fine to drive the car to a dyno about 35 miles away to get tuned with e85 the setup is h22 1000cc injectors, skunk2 stage 2 turbo cams, built bottom end precision 6262bb etc etc also what kind of base fuel pressure were you using for this 60psi? higher? Thanks in advance because im a complete tuning noob :D
on the car it was stock at 45psi so if your at 60psi then your all good and if you have a wideband the fuell will be a lil bit richer and the cams your running as oppose to the stock that the car was tuned on but overall you should b good
LGMotoring
Lgmotoring.com
Lgmotoring.com
patroick67
thanks for the reply this tune will be put to good use thanks man
