Safe base map request for K24/K20 with 12.5:1 compression
samurai_lhk
Post by samurai_lhk »
Hello guys! I really need some help.
I need to brake in my engine before tune, but I'm afraid to damage my build.
I need that someone approves my calibration or gives me other..
Here is calibration with what i want to start and break in my build:
K24K20 12 kompresija.kal
This file is a little bit modded from - New calibration - Other vechicles - K24-race-650cc.kal (with 12.5:1 compression).
Engine:
K24a1 87.5mm bore
SCAT H-Beam rods
Supertech pistons 12.5:1 compression
Stock K20a2 TypeR head
JDM 6 speed gearbox with 4,764 final
Cold air intake
Custom 4-2-1 60mm exhaust
Mugen twinloop
TypeR K20A oil pump mod
No Power steering
Kpro
VTC is set to 40max for safety with 12.5:1 comp.
I'm using 310cc injectors for now. After brake in i will use 410cc RDX injectors.
So please check out my calibration. Will it be good for my build?
Can you give me other, better file? Or this will be fine for brake in?
THANK YOU VERY MUCH!
Please, watch my Honda video and press like - http://www.youtube.com/watch?v=HaX5ERw0DwE&feature=player_embedded
samurai_lhk
Re: Safe base map request for K24/K20 with 12.5:1 compressio
C'mon some smart people are here.. Why this forum is so quiet? :(
sharafanta7
Re: Safe base map request for K24/K20 with 12.5:1 compression
Post by sharafanta7 »
That was very helpful thank you very much
