Use all columns in NA calibration
myuser
Post by myuser »
Hi,
What are the Pro's and Con's for changing the tables in a NA calibration to "Show all columns" and change the "Vacuum Unit" columns in the tables to use only the values NA (-26,0"..0,2") for column 1 to 20 to give detail to certain vacuum areas in Ignition, Fuel and Cam's tables?
The ECU will execute all the NA functions correctly?
In some calibrations the option "Show all columns" only show's the 1 to 10 columns.
Is this normal?
Example: Si(FG2/FA5-MAF) show only 1..10 and FN2-MAF 1..20
Best Regards,
JP
Re: Use all columns in NA calibration
There really is no need to do this as the values are interpolated between the different columns. This is how the car is tuned from the factory and it is more than adequate. The added columns are only used for boosted applications.
