D16z6 Vatara Build
Monnoracing
D16z6 Vatara Build
Post by Monnoracing »
I have a d16z6 with the p2p0 vatara kit so the cpr is 8.4:1. Running the motor NA until I finish everything with my SC. I will be going turbo later down the road. So thought I could run my stock ecu but hell no it was running lean as can be. Never put much thought into that lower cpr equals more air in the cylinder. I installled the s300 and came up with this tune running around the streets.
