will not start
hatchsiturbo
will not start
Post by hatchsiturbo »
just finish my swap and car wont start up
here the setup
prb kpro 02-04
k24a4
06 type s trans
rbc manifold
rbc map sensor
04 type s throttle body
iacv delete
rbc stock injector
hybrid racing full race conversion harness
255 fuel pump and stock mr2 spyder intake fpr
i have change vtc, ckp, both cmp sensor and still have code p0341 vtc phase gap
i have use k20a2 kal file and k24 kal file and still wont start but i when i decrease fuel map in the 50 degree map ...it'll struggle to start up then die
the setup k24a4 swap is in a toyota mr2 spyder
http://youtu.be/3dUcHCI9NyU how the engine sound when try to start up
Re: will not start
There's no point trying to start the car while there are error codes. From the datalog the MAP sensor doesn't look like it is reading and the ECT jumps all over the place, so there are wiring problems.
Go to http://www.hondata.com/techk20wiring.html and trace the wiring to make sure the swap harness is good. Trace from the ECU pin to each cam sensor as well as the crank sensor. Check the cam and crank sensors are getting power to the correct pin on each one. Also check the crank sensor is not a K24 type with a K20 plug.
Also check that the throttle body is allowing the MAP sensor to see the manifold pressure. Finally, what was the idle control removed? It's not going to idle nicely without the IACV.
