100% Duty Cycle Safe?
Posted: Sun Jan 08, 2012 5:51 pm
So here is the set up:
Built B20 8.8:1
B16 head w/ Type R internals
Edlebrock Victor X Mani
GT3076R Turbo
Tubular Ex. Mani
1000cc Bosch
Walbro 255
Stock Fuel lines
AEM rail & reg (set to 30-32psi)
E85 fuel
s300
Boosting 26psi (boost cut 28psi)
Had the car tuned last late March, early April (in AZ), when the ambient temps where somewhere in the range of 85-95 degrees. The car ran great after the tune with 520whp and the injector duty cycle was around 85-90%. Did a project on the car and finally got it back together and running. Now it is January and the ambient temps are around 65-80 degrees when I drive it. Now with the colder weather, I am hitting my boost cut in 4th and 5th and maxing out my injectors to 100%. I am maxing out duty cycle around 6000rpm and 20+psi and my wideband is starting to lean out.
My tuner says that I can hit 100% duty and still be getting enough fuel. If i continue to climb in the RPMs (rev limit is 8300), the engine feels like it is misfiring (or detonating). My tuner also thinks that the cooler, denser air is not a factor.
My question is this: is the colder air/weather a factor? Do I need a totally different tune for the winter? Am I maxed out on my fuel pump? Is it safe to run the injectors at 100% duty cycle? Isn't there an air temp compensation built into the s300 for situations like this?
If all else fails, I am thinking that I need to upgrade the fuel pump, bump up the rail pressure, and retune. I have added a couple datalogs. Please let me know what anyone thinks. Thank you in advance.
Built B20 8.8:1
GT3076R Turbo
Tubular Ex. Mani
1000cc Bosch
Walbro 255
Stock Fuel lines
E85 fuel
s300
