Feed to E8 required?
Muu
Post by Muu »
Hi
The lotus O2 relay is hardwired to the main relay (in one unit) so it just comes on with the main relay.
Question is, does E8 need to see a 12v signal to not think there is an issue with a dead relay?
T
Re: Feed to E8 required?
No, if E8 has +12V with any current it will burn out. I'd suggest not using the lotus relays (or relay box) and using individual relays.
