**H22 boosted Revs drops to 0 after acceleration**
Posted: Thu Dec 29, 2011 8:31 am
Hi people, Felices Fiestas a todos los foristas, Hondata the Best!
Just as say the title, my revs drop to 0 when accelerating, idle is missing after accelerating the engine. This is a new one project never used before.
Details of setting;
-H22A engine, Prelude SI chassis
-Wiseco Pistons 87mm 8.5:1 compression
-Eagle rods, sleeved
-MSD 72lb injectors read 2.3 OHM, Prelude OEM resistor box (756cc, I need change dead times for this one?, a friend with RC750cc did no change it and car run well)
-38lb fuel pressure on idle
-Balance shaft removed by Kaizenspeed kit
-Ported and polished Head (It was done when was N/A)
-No vacuum leaks, revs on idle remain stable at 1000rpm
-Timing 16 degree
-MAP sensor Ommi 3bar, offset value changed
-TPS reading 0.46v on idle and 4.6 at WOT, scaled on S300.
-Walbro fuel pump 255lph
-PLX wide band
I make a mistake, Into fuel trim option I put 720cc instead of 750cc, Only this is wrong in this calibration.
attached calibration and datalogs...Help me pls!
Details of setting;
-Timing 16 degree
-PLX wide band
