Hondalogger - recording triggers?
Jamie
Post by Jamie »
Is there any thoughts to adding recording triggers to the Hondalogger software. I use similar datalogging software for work which I can set up triggers to begin recording - variable on what ECM input and its value.
Example: trigger recording at 50 rpm or trigger recording at 10psi MAP signal.
Pre-trigger and Post-trigger time adjustment would also be useful.
Maybe not a nessesary feature but I find it very useful to diagnose and calibrate engines at work. Also much safer when datalogging a running issue on the street.
CivicVTi
Post by CivicVTi »
Palmlog can be triggered if you have one
Jamie
Post by Jamie »
CivicVTi wrote:Palmlog can be triggered if you have one
I have not used Palmlog yet, Thanks I will have to check that out. :D
