KPro - Clutch Switch
05typeR
Post by 05typeR »
what is the time period the ecu cuts engine power (fuel or spark or both)?
i know with some ECUs you can set it to X amount of msec, but looking at the kmanager i dont see anything of the sort.
Re: KPro - Clutch Switch
I don't understand your question. ff you are talking about a rpm cut based on an input switch, then it is as soon as the input is triggered.
05typeR
Post by 05typeR »
the kpro is capable of allowing flat shifts.
my question is: does the kpro kills the engine rpm for as long as you have the clutch pedal depress or will it regain engine power after lets say 1millisecond?
whenever the input switch is activated it is cutting the RPM.
05typeR
Post by 05typeR »
Spunkster wrote:whenever the input switch is activated it is cutting the RPM.
yes, this i understand. . .what i wanted to be clear on is it keeps the rpm cut until you release the pedal? at this point i assume yes it does.
while other programming management systems allows you to set a time period.
