close loop settings question for b16a itb
fuel-built
Post by fuel-built »
hi i want to know how to set the close loop settings :minnimum and maximum short term adjustment for an b16a itb with 44occ inlectors ,the stock set up when i put the built in calibration for ls itb from s manager is :
minimum -30
maximum 47
tell me if is that right or i must change it thanks !!!
fuel@built all motors
fuel-built
Re: close loop settings question for b16a itb
also i want to know how to set the rate of chsnge for :
under 1000 1000-2500 2500-4000 over 4000rpm
slow
rich -to lean
lean to rich
i must set it or let is as it from the built in calibration???
my engine is b16a itb 440cc inject 50psi fuel pressure thanks
fuel-built
b16a itb ignition controlled idle
hi i want to know how to set this for my b16a itb ,i must change it or i must leave it as in the built in calibration for itb thanks
Progress
Re: b16a itb ignition controlled idle
Post by Progress »
i think u have to change from using map sensor to tps sensor since u can't have vacuum
tuning upon request
347-989-5028
9.23@167 B18C street/track tuned
HP unknown
Progress
Post by Progress »
you need to tune the car first otherwise it will effect close loop opperation
tuning upon request
347-989-5028
HP unknown
fuel-built
help b16a itb with map or tps
hi i want to ask the s300 built in calibration for itb have the low speed table tune with tps and the high speed table with map .
hondata says that itb only tune with tps so i alter the secondary tables with tps also is that right??? please help
also how to set overrun fuel cutoff(tps) throttle the stock calibration for itb is 0.6%
and how overrun fuel cutoff map is that need to change cause i tune with tps ???
fuel-built
fuel and ignition for launch limiter
i want to ask how to set the fuel enrichment and ignition timing for my b16a itb
i want at launch to throw flames of my exhaust with out damage anything please how to set :
fuel enrichment % and how ignition timing retard thnaks
fuel-built
target lambda settings for b16a itb
please help me how to set the target lambda for b16a itb
i set the low 14.7
medium 13.5
high 13.3 is that right for all motor itb ?
fuel-built
help how to change the rpm and tps index values
how to change the rpm and tps values ?
when i try to set a higher rpm value from original 8000rpm in the table when i insert a value 8200 e.g the 8000rpm does not shows then and i see e.g 7000rpm and then 8200rpm how to edit more rpms at the table and more tps columns?
how to set properly the tps index values for itb b16a ?how many column i must set ?
the built in calibration has : 1-3-7-10-15-20-25-30-35-40% tps only how many column i must set and with which number of % tps ???
at tuning with map from 1-5 column i must be 14.7:1 and at 6 13.6:1
in tps i must be until 50%tps 14,7?? ant at 60% 13.6???
help me
fuel-built
air temperature compensation parameters problem help!!!
hi for b16a itb i must change the fuel compensation parameters with air temperature and water ???
cause i tune with tps only and the engine does not see map presure and intake air temperature
please help and tell me hot to set is right thanks
fuel-built
injector phase for itb b16a help
hi i want to ask hot to set the injector phase for my itb b16a proper
the built in calibration for itb is :
low load high load
cold 405 405
hot 480 450
is that right for open my injector or not thanks a lot
fuel-built
problem with lucas 440cc injector pulse width to voltage
can anybody help me to set my injector pulse width to voltage conversion on my b16a itb ? thanks
the setting that has the built in calibration for itb is :
volts 0 8.09 10.11 12.13 14.16 16.08 24.55
ms 1.49 1.49 0.96 0.68 0.49 0.35 0.35
is that okey ?my fuel pressure is 50 psi thanks
I've merged all your individual posts into one topic.
fuel-built
lean protection setting for b16a itb
hi i want to ask how to set the lean protection parameter proper for b16a itb
i must use only the one protection or both ?
how to set the trigger time and how the engine load cause i tune with tps thanks
fuel-built
help how to set injector voltage compensation for b16a itb
hi i want to know how to set the injector voltage compensation ms to voltage for lucas 440cc injector i can not find the minimum pulse width the calibration shows :
volts 0.0 8.1 10.1 12.1 16.1 24.6
dead time ms
help me to set for itb b16a
