Car wont start
Passnu2
Car wont start
Post by Passnu2 »
Purchased Hondata new and just completed the install. Its linked with my car and downloads were completed...
Not sure what to check of look for on the data-log or anything else to see if there is something that I have missed. Car did turn over with the S/C belt off so I know the car is getting fuel prior to the ECu flash. So only change is the ECU flash and the S/C belt installed. I used the base line map for 06+ Supercharged with 650cc injectors and changed the MAP to Hondata 4 Bar. Car just turns and wont fire.
Thanks for your help and feedback!
Re: Car wont start
If you could post a brief datalog (a couple of seconds cranking is ok) and the calibration. If all else fails, put in the stock injectors & MAP sensor, then see if that will start.
Passnu2
Re: Car wont start
Post by Passnu2 »
Thanks for the quick reply...let me know if this is what you need and that I saved it correctly.
Re: Car wont start
Nothing in that datalog. Let's start with the basics. Download and install the latest (beta) version of FlashProManager from the downloads page. Connect the FlashPro to the laptop and vehicle, then switch on the ignition. Check that there are four checked boxes on the bottom left (driver, flashpro, obdii, ecu). Upload a base calibration for you injector size. Don't worry about the fine details of the calibration. Upload the calibration. Then check you can datalog. Then start the car. If there is a problem at any stage, don't go any further - fix the problem first.
Passnu2
Re: Car wont start
Post by Passnu2 »
Ok I can give that a try...maybe a stupid question but what data will it log if it doesnt start?
Re: Car wont start
It should log the sensors readings and show if the crank and cam sensors are working, then will give the injector pulse as well.
