k20a2 turbo base map
Posted: Wed Oct 26, 2011 8:32 pm
Engine:
k20a2 block
Wiseco Speedlab spec pistons
Blueprint pro h beam rods
Tool steel upgraded wristpins
Blueprint headstuds
Polished and balanced crank
ERL s2000 oil pump
k24 oil pan
Full balance and blueprint using all brand new oem Honda
bearings , chains , tensioner , new gaskets , and seals
Head:
Speedlab spec port job
Supertech valve springs w titanium retainers
Supertech nitrate coated ss intake valves
Supertech inconel exhaust valves
IPS KT1 cams
Spuntek lower timing chain guard
NGK spark plugs
Transmission:
ep3 5 speed
Wavetrac LSD
CC twindisc
Tilton CMC
Braided SS custom made hydraullic clutch line
Fuel:
Hybrid Racing Fuel Rail
All black an fittings
-6AN & -8AN SS lines
Aeromotive A-1000 FPR
AutoMeter Fuel Pressure guage
1200cc Precision injectors
Dual intank Walbro fuel pumps
Engine Management:
Hondata Kpro
Hondata 4 bar map sensor
Hondata boost controller
Autometer Oil Pressure Guage
Autometer Coolant Temp Guage
Hi / Low boost switch
Running e85 gasoline , calibration request please.
k20a2 block
Blueprint headstuds
ERL s2000 oil pump
k24 oil pan
Head:
IPS KT1 cams
NGK spark plugs
Transmission:
ep3 5 speed
Wavetrac LSD
CC twindisc
Tilton CMC
Fuel:
Engine Management:
Hondata Kpro
