K-Pro O2 Heater Problem on PRA ECU
Posted: Tue Oct 25, 2011 1:08 pm
by marklamond
Hi there,
I am having some problems with the O2 heater drive on a 38720-PRA-E11 ECU, fitted with K-Pro.
The Secondary O2 is disabled.
The Primary O2 Sensor is connected up as follows:
What should happen is as follows:
1) IGN is turned on.
2) Pin E8 pulled to ground, O2 heater relay engaged. +12v applied to O2 heater and Pin A22.
3) Pin A1 pulled to ground, O2 starts heating.
4) When O2 has heated up, pin A1 is modulated as required to maintain temp in heater.
The problems all relate to the fact that the O2 relay drive (pin E8) is not being pulled to ground to actuate the heater relay.
If you link pin A22 to A2 to provide +12v to the heater relay directly (as advised by Hondata), you get another O2 heater error after the O2 has warmed up.
The ECU & engine was taken from a UK CTR with the O2 wired in this configuration. It was sent to Hondata to have the K-Pro fitted, and on return the O2 output is not working.
Full details of exact error codes, and K-Pro revision to follow shortly - waiting on the owner sending them up.
Thanks,
Re: K-Pro O2 Heater Problem on PRA ECU
Posted: Tue Oct 25, 2011 1:48 pm
A PRA ECU cannot run a AF sensor. The AF sensor can only be used in a PRB, PRC, PRD or PND ECU.
Posted: Wed Feb 22, 2012 5:10 am
by robctr.
hi I have this same problem. so dose that mean you go into k manger - parameters - closed loop and disable closed loop or others ?
Posted: Wed Feb 22, 2012 10:12 am
More than likely you are trying to run a PRB calibration in a PRA ECU.
Posted: Wed Feb 22, 2012 1:46 pm
by marklamond
I totally forgot about this, makes sense!
The owner was fidding around with it a lot, i bet that's what has happened. Never did follow it up as i was being expected to spend hours on it for free, and my good nature was being somewhat exploited. :)
Posted: Wed Feb 22, 2012 3:06 pm
by robctr.
got mine sorted this evening. went into the pre-set hondata pra map (rolling road tune)
clicked use secondary 02 sensor for closed loop operation and upload the map code gone eml off :)
Posted: Fri Jul 27, 2012 2:43 am
by Hoffy
robctr. wrote:got mine sorted this evening. went into the pre-set hondata pra map (rolling road tune)
Sweet,
I have the same problem.
Ill try this out this afternoon.
Is the O2 heater function functional by you guys?
When I enable it i get a heater circuit malfunction error,
Mitch
Posted: Sun Jul 29, 2012 1:22 am
by Hoffy
Sweet,
When I enabled it I get a heater circuit malfunction error,
Mitch
Hi Guys,
The problem is fixed by "use secondary 02 sensor for closed loop operation".
Can anyone explain to me why this is so and what is happening exactly?
Because nothing is connected my the 2ndary O2 sensor plug and if I enable the O2 heater I still get a heater circuit malfunction.
Thanks,
Mitch
