Page 1 of 2
Hondata R18
Posted: Mon Oct 17, 2011 11:32 am
by 420Coupe
Is there an option to edit the Final Drive like there is for the Si as i am going all out with this build fully building the engine and taking it up to 25+lbs on boost. Was just wondering if there was a way for the speedo to be adjusted to read the correct speed with the corrected new final drive. Thank you ahead of time.
Re: Hondata R18
Posted: Fri Oct 21, 2011 10:26 am
Currently there is no option for this, and it may not be something we are able to add.
Re: Hondata R18
Posted: Mon Oct 24, 2011 6:01 am
by nyghtstalkr
Yes, this feature would be nice, along with a Wideband option menu in closed loop like the Si Flashpro. I have an Auto R18 and plan on taking it to 300 whp so features that are in the Si Flashpro would be nice so that it can properly tuned and adjusted.
Re: Hondata R18
Posted: Wed Dec 07, 2011 10:02 am
by 420Coupe
Would there be any way to annoy doug enough to get him to be figure out how to program boost by gear in the R18 ? this is something that i find essential in order to be able to perform and maintain traction on the 1/4 mile.
as well as in contact with Ferrea Racing to make a custom rocker in order to have a TRUE VTEC for the SOHC R18!!!
DEREK/DOUG have i peaked your attention yet!! :dance:
Re: Hondata R18
Posted: Tue Jan 03, 2012 9:35 pm
by chungyfied
Boost control with hondata would be awesome. I hope this can happen for the r18. Another thing that would be awesome is if we could have a display hooked up to the flashpro to act as a gauge.
Re: Hondata R18
Posted: Mon Feb 20, 2012 10:40 am
by 420Coupe
So Derek/Doug is there any way to swap an RSX/SI ECU system to work around this MAF sensor issue and be able to tune using speed density ? this is the only thing holding back my current build as we are only going to be able to push max around 450 whp tuning with the MAF the speed density will solve this issue instantly and allow to bbg and several other little tweaks. Any suggestions/opinion would be plenty useful especially from DEREK
Re: Hondata R18
Posted: Sun Mar 11, 2012 5:27 am
by 420Coupe
Derek,
How much money would i have to pay for you to design me my R18 speed density based flashpro ?
Willing R18 Owner,
Cash IN HAND.
:waiting:
Re: Hondata R18
Posted: Sun Mar 11, 2012 9:45 am
Nothing, because it has already been done. Release ETA would be a couple of months.
Re: Hondata R18
Posted: Sun Mar 11, 2012 1:04 pm
by 420Coupe
Hondata wrote:Nothing, because it has already been done. Release ETA would be a couple of months.
Can i PAYS GRATUITY regardless !?
:bow:
Re: Hondata R18
Posted: Tue Mar 13, 2012 4:17 pm
I've added the feature into the current beta release. Note that when using the speed/density fuel table option it is a little tricky to tune the fuel tables for the 'high' cam. You can do it, but it is hard to get the car to run on the high cam apart from some fairly narrow throttle parameters.
Re: Hondata R18
Posted: Tue Mar 13, 2012 8:20 pm
by 420Coupe
Thank you! im assuming releasing more as you get it done and or is the speed/density based fuel table. have to get this damn motor together already and start playing with this!!!
Re: Hondata R18
Posted: Wed Mar 14, 2012 1:13 pm
by ghostmonky
What does the Speed density tuning mean to NA R18 with a catback and SRI and is this a MAP tune?
Re: Hondata R18
Posted: Wed Mar 14, 2012 2:17 pm
It means that it can now be tuned using map based tables instead of the AFM.
Re: Hondata R18
Posted: Wed Mar 14, 2012 3:32 pm
by 420Coupe
Spunkster wrote:It means that it can now be tuned using map based tables instead of the AFM.
Is this all thats being added or is more being implemented slowly as you reverse engineer from the CRZ ?
Re: Hondata R18
Posted: Thu Mar 15, 2012 8:46 pm
by chungyfied
Hope you dont mind squeezing in another comment here.
Does hondata intend to allow boost control through the flashpro? I've been holding back on hooking up my boost controller in hopes that flashpro can do the job.
Also, it would be great if ignition compensation by gear can be added
