Can't rev over 1900-2000 RPM
Posted: Sat Oct 08, 2011 6:46 pm
by SuperK
I'm not sure if this is a a Kpro problem or a vacuum leak.
I have searched for leaks and can't find anything.
When I depress the throttle and it gets up near 2000 RPM it just cuts off and jumps back down to idle. I can't figure out why and I', new to Kpro so if there is something I should be setting up to fix this please let me know. I have a K Tuned TPS and I made sure to set it off the bat.
Re: Can't rev over 1900-2000 RPM
Posted: Sun Oct 09, 2011 9:16 am
Check that lean protection is disabled.
Posted: Sun Oct 09, 2011 1:22 pm
by SuperK
1 and 2 are disabled.
I did all my gaskets on the TB last night and tried blocking off the iacv with the ktuned kit. Its still dropping rpm above or around 2k. Could it be timing or a fuel issue in kpro?
Posted: Sun Oct 09, 2011 5:41 pm
Check that boost cut is disabled. Failing that, follow the posting guidelines and post your calibration plus a datalog.
