base map
civicturbo1976
base map
Post by civicturbo1976 »
hi guys im in need of help with a base map for my b18c boosted . need to put some miles on engine be for it gets mapped. im running 770cc inj. t78 greddy turbo . not sure what other info ur need as im all new to this . hope u guys can help.
tb144050
Re: base map
Post by tb144050 »
civicturbo1976 wrote:hi guys im in need of help with a base map for my b18c boosted . need to put some miles on engine be for it gets mapped. im running 770cc inj. t78 greddy turbo . not sure what other info ur need as im all new to this . hope u guys can help.
In hondata, click "File, Open" and you can check out the settings and overall map of the b18crevhardTURBO.....use at your own risk. I am not boosted and have never used it, nor even looked at it, but it seems like a good start for a base map.
Of course, you will want to review the "parameter, fuel trim" to account for your bigger injectors and whatnot. The basemap is just supposed to be good enough fuel and ignition to get you to the dyno for proper tuning. NO hard driving, or you risk detonation and knock with an untuned basemap...both of which can each kill an engine..
--TJ
