I thought I would be running lean b/c of the comparisons between ITR and H22, especially with my skunk2 intake manifold and throttle body....maybe I misinterpreted what I read about using the p72 map...I am a noob after all.
So far, it runs ok at very low throttle and speed....just driving a few blocks to work and back. However, I am averaging 10-11 on my lambda tables even after it warms up on a 10 minute, low throttle drive. I am using my factory o2 sensor (narrowband) bc buying a wideband sensor is not in my budget for a whiiiillle. I do however have a narrowband analog AFR gauge sitting in my shop if anyone has a good reason why I should put it in. I also wonder if my external coil is not putting out enough spark to burn the gas completely, leaving it rich??? Is there a way to check the strength of the spark? (noob, i know)..
Please be aware that I have not modified anything related to fuel in this map yet. The "stock p72 map" (that is included with hondata) lists the stock and current injectors to both be 240cc. I can't remember if I am running jdm 345 or us 290 injectors....my friend has a ton of honda parts and this is the second build he has thrown together for me.
Soooo...any help would be greatly appreciated. I know it's better to run rich than lean, but I don't want it so rich that I might be losing hp or fouling spark plugs, etc.
1995 Honda Accord
h22a1 engine swap
5sp trans
exhaust
intake
intake manifold
Just by reviewing the software from my living room recliner, I have decided to experiment with the following settings. Some are no-brainers, but some are based on theories I've read and none have been tested by me yet. Use at your own risk, but I am posting this up here because....this is useful information on how to use the software in a detailed, How-To format.
In Parameters, Vtec: Vtec increased to 5200 rpms and lowered to 500 mBar. Disabled "Spool Vtec Error".
In Parameters, Idle: IAC error disabled.
In Parameters, Rev Limits: Fuel rev limit lowered to 7324 from 8484.
In Parameters, Misc: Disable Knock Sensor. Disable ELD.
How do I lean up the p72 map for an h22a1?
Re: How do I lean up the p72 map for an h22a1?
aem wideband or innovative or even auto-meter wideband and you will see exactly where u need to lean and where to richen up tuning fuel tables with out wideband and extremely difficult when u dnt know what the fuel is like
LGMotoring
IG:Lgmotoring_official
Lgmotoring.com
Lgmotoring.com
