The Official HOW DO I/ WHAT IS thread for noob questions!
tb144050
Post by tb144050 »
The purpose of this very thread is to be the GO-TO-POST place for all the noob questions!! I, along with thousands of noobs, have had millions of questions over the last ten years...yet there is still no indepth tutorial/walkthrough for complete noobs. So here is the place to post the questions we all have, but are too embarassed to ask.
Hondata pro's: PLEASE take the time to visit this thread often to provide guidance and nourish our growth and knowledge? Remember, this is to be the tutorial page for noobs. Therefore, heckling and the order to "SEARCH" are strictly prohibited please. :)
Hondata MODERATORS: PLEASE sticky this and let the Hondata community create our own tutorial/reference page for all of our HOW TO/WHAT IS questions? Eventually, someone may come along and compile all useful information into a simpler, less random format.
Thank you all in advance for your support from the entire population of future Hondata tuners!! :)
--TJ
Yes, i am a noob. I bet you were a noob once upon a time. lol
tb144050
Re: The Official HOW DO I/ WHAT IS thread for noob questions
Post by tb144050 »
I will be the first to get this kicked off:
1: What do the numbers under the throttle 1-10 scale (next to the ") stand for?
2: One of the very first steps on hondata's tech page says to adjust the "injector multiplier." I have a general concept of what this is, but I do not see anything in the menu's or parameters that says "injector multiplier." So where do I change that?
3. Should the timing tables EVER be changed? What kind of mods would require a timing adjustment to any cells?
More questions to come...I will answer my own if I find the answer first so that others can learn. Remember tens of thousands of noob tuners have looked for the answer to these exact questions when they first started... :)
tb144050
Post by tb144050 »
4. Under ideal tuning, should the fuel tables (viewing the lambda) be identicle to the Target Lambda view of the same tables? (Yes, that is as simple of a question as it sounds..just a noob wanting to make sure)
"View" "Lambda" tells me I am averaging 10-11 in each fuel table cell, but "view" "Target Lambda" shows my target (goal) to be 14.7 in most cells under the throttle columns 1 through 6ish. So, correct me if I am wrong, but I am going to asssume that I am averaging 10-11 parts air per 1 part fuel, soooo...I am running lean, right?
5. Under the same tune, if I press "view" "fuel change" then I see that all cells have a (-)negative value, mostly averaging 25-40% in each cell. Does that mean I need to decrease my fuel that is being used so that the AFR will reach "Target Lambda"?? (Yes another simple question...noobs need your advice...we are lost without you)
--TJ
tb144050
Post by tb144050 »
tb144050 wrote:4. Under ideal tuning, should the fuel tables (viewing the lambda) be identicle to the Target Lambda view of the same tables? (Yes, that is as simple of a question as it sounds..just a noob wanting to make sure)
--TJ
Answer found via:http://forums.audiworld.com/showthread.php?t=2580765
"Fuel Trim Information (Running Rich or Lean?)
Some of the most common fault codes (DTC's) pertain to fuel trim. Here is an explanation of fuel trim and what it does for us.
The ECU controls Air/Fuel mixture in order to maintain power, efficiency, and emissions. A/F is expressed as either a ratio (14.7:1 for example) or as a Lambda value. With iso-octane ("ideal" gasoline), Lambda of 1.0 is equal to 14.7:1 A/F. This is known as "Stoichiometric", a condition where there is a perfect balance between oxygen molecules and the various hydrogen and carbon based molecules in petroleum. With the oxygenated gasoline that most of us use, actual A/F ratio of 15:1 is closer to stoichiometric.
If Lambda is greater than 1.0, then there is a surplus of air and the engine is running lean. If Lambda is less than 1.0, then there is a surplus of fuel and the engine is running rich. It should be noted that the ratios are mass-based, not volume-based.
So, why don't we always run at 1.0 all the time? Well, we do MOST of the
time. At cruise and idle, mixture is held tightly to 1.0 to keep the catalytic convertor at optimal efficiency, so the emissions are minimized. However, when we need acceleration, the mixture gets richer. Why? Maximum power is made between 0.85 to 0.95 Lambda (12.5 to 14.0 A/F with iso-octane). So, under acceleration, mixtures get richer. Sometimes you want to get even richer under acceleration to keep detonation (pre-ignition of the mixture from excess cylinder temperatures) away. The 1.8T has a relatively high compression ratio for a turbocharged engine, which especially under lots of boost, is very succeptible to detonation)."
Soooo...I can assume the answer is "Yes." I do want my Lambda to be as close as possible to the Target Lambda (just as simple as it sounds). At higher rpm's, Target Lambda will be less than 1 to make more power in those rpms.
And yes, my 10-11's AF Ratio's are too rich and not optimal for power, emission, or gas mileage. I am probably losing power by running that rich.
--TJ
tb144050
Post by tb144050 »
tb144050 wrote:I will be the first to get this kicked off:
The " represents a unit of measure for vacuum pressure. This can be changed by clicking "Options" "Settings" and then selecting the tab titled "Units." In this section, you can choose from 3 units of measure: millibar (mbar), kilopascal (kpa), and Inch (").
In most of the info I have read on forums, mbar is commonly used as the measuring unit...so for now, I will be tuning with mbar's.
--TJ
tb144050
Post by tb144050 »
More useful info...copied from and full thread/info available at: http://honda-tech.com/showthread.php?t=586043
HONDATA TUNING TIPS
Here are some tips to help you understand Hondata tuning. Other tuners feel free to chime in.
Which Base Map to Start with?
If the motor is completely stock then use the map for that motor. These are the exception. (of course calibrate for different sized injectors)
ITR - use JDM P30 map scaled to 1.8L from 1.6L
GSR with Skunk IM - use JDM P30 map scaled to 1.8L from 1.6L
H22 - use P72 map scaled to 2.2L from 1.8L
H22 with Euro IM - use JDM P30 map scaled to 2.2L from 1.6L
B20B - Use P74 or 75 map scaled to 2.0 from 1.8L
B20Vtec with B16 Head - use JDM P30 map scaled to 2.0L from 1.6L
B20Vtec with GSR Head and GSR IM- use P72 map scaled to 2.0L from 1.8L
B20Vtec with GSR Head and Skunk IM- use JDM P30 map scaled to 2.0L from 1.6L
In general you can add like 5-7% fuel to columns 8, 9, 10 with the hotter Vtec cams currently available.
Note: A map for a NA motor is basically the same as a boosted motor (on Hondata). Think about it a little. When not in boost your motor is running NA and when boosting it runs in the boosted portion of the map. Pretty simple.
Hiccuping and Coughing under Light Cruise
The first 7 columns of the fuel map should give you 14.7:1 (Lamda=1) air fuel/ratio. If not your car will hiccup and cough under light cruise if you run closed loop. You may also need a little more timing.
You must tune for 14.7:1 A/F if you want to run in closed loop(uses the stock o2 sensor - gas saving) operation.
Note: A lot of tuners don't tune this portion of the map and hence the car won't run well in closed loop operation.
Also Note: It maybe beneficial to run in open loop with lower than 14.7:1 in this portion of the map if your motor has too much compression for the gas that you are running.
Here's a pic showing which showing the 14.7:1 areas of the map. (This can be found under File menu, menu item "Settings", tab "Lamda" in the ROMEditor.)
Changes to the Fuel settings in the Low rpm portion of the map affects the A/F in the higher RPM
This is why you tune the lower rpm ranges AND driveability (tune for 14.7:1) FIRST.
For example, if you lean the map at 2,000 rpms you'll run leaner higher up in the rpm. Converserly, if you richen the map at 2,000 you'll run richer higher up in the rpm.
Once you get your driveablity down extrapolate to the rest of the map and take passes at wide open throttle (WOT) and clean up the WOT portion of the map.
What's a good ignition timing?
For idle it should be 16 - 20 degrees.
For WOT operation it depends on the particular engine but most Honda's I've seen like 24 - 28 total timing in the high rpm (4.5k+) and high load (3 last columns) for NA apps (22-24 degrees for FI apps).
Re: Hondata Tuning Tips (ninjanick)
Quote:
Originally Posted by ninjanick
Rocket,
I had a few questions regarding timing:
1. Do you actually tune the ignition map in the lower left corner? Seems like this part of the map would pertain to deceleration primarily.
2. Is there a better/alternate way of tuning ignition timing other thank audible knock? I've heard comparing torque curves between runs is a way, however consistancy in the dyno, weather, etc ... might make this difficult. Any suggestions?
1. This area is usually not modded. Under deceleration the ecu doesn't give the engine any fuel so it is a non-issue. Also I don't think any of us drive in super part throttle at 6+K rpms.
2. Ignition tuning is tougher to play with. One some dyno's like a mustang dyno or engine dyno you can hold the rpm steady and tune fro maximum torque. I am guess that's how Erik's Racking does their tuning on the DynaPacks. That's the way to do it. But on DynoJets this can't be done easily.
Quote:
Originally Posted by 99_SH
Could you explain why there is less timing at higher loads?
Under higher loads, ie the throttle is open completely the density of the air is higher (full atmospheric as opposed to partial vacuum). The higher the density of the inlet charge (air/fuel) the faster it burns and hence less timing is required. Just like how boosted motors don't need as much timing. Higher inlet charge densities.
tb144050
Post by tb144050 »
Just by reviewing the software from my living room recliner, I have decided to experiment with the following settings. Some are no-brainers, but some are based on theories I've read and none have been tested by me yet. Use at your own risk, but I am posting this up here because....this is useful information on how to use the software in a detailed, How-To format.
Target Lambda table values lowered by clicking Options, Settings, Target Lambda.
Lambda Engine Load
------Low load___________1_____below_____600_____mbar
------Medium load_______0.92___between
------High load__________0.85___above____930_____mbar
(This should lower the rpm needed for a richer mixture to be used.)
In Parameters, Vtec: Vtec increased to 5200 rpms and lowered to 500 mBar. Disabled "Spool Vtec Error".
In Parameters, Idle: IAC error disabled.
In Parameters, Rev Limits: Fuel rev limit lowered to 7324 from 8484.
In Parameters, Misc: Disable Knock Sensor. Disable ELD.
Anyone have input on ANYTHING they have read here in this entire thread? Confirm, discuss, debate anything??
--TJ
tb144050
Post by tb144050 »
How many "bar" is my map sensor that came mounted to my skunk2 throttle body?
How many "bar" is a stock h22a1 map sensor?
tb144050
Post by tb144050 »
tb144050 wrote: How many "bar" is a stock h22a1 map sensor?
Answer via: http://www.preludepower.com/forums/show ... p?t=308610
ambient atmospheric pressure is ~14.5psi aka 1 bar. so a 1bar map sensor will only read between full vacuum and ambient pressure. a 2bar map sensor will read 1 bar of vacuum and 1 bar of positive pressure (boost), so a 2bar map sensor will read up to ~14.5psi of boost.
stock honda map sensors are 1.75bar, meaning they can read up to 10-11psi of boost.
2bar - 14.5psi of boost
3bar - 29psi of boost
tb144050
Post by tb144050 »
tb144050 wrote:How many "bar" is my map sensor that came mounted to my skunk2 throttle body?
Well, the label on my MAP sensor that came on my second hand skunk2 intake manifold shows: Sensor Assy, Map.....DENSO.....TN079800-3280....5v ps-30.
Local internet chatter says that "5v ps-30" MAP sensors are interchangeable "stock" Honda Map sensors. :o
tb144050
Post by tb144050 »
Here is a very long read, but well worth every minute you spend reading or re-reading it.
via: http://www.8thcivic.com/forums/hondata/ ... uning.html
Hondata: A Guide to Tuning
This is an edited set of notes from Conrad H. Blickenstorfer on a K-Pro seminar that Hondata presented back in 2004. I found this to be a very useful and informative guide to the basics of Honda ECU functionality and the tuning methods of Hondata. Much of the information presented here was originally for the K-Pro and RSX Type-S, but the FlashPro and Civic Si functions in a similar manner, so I felt that posting it can still be useful to the community. It should be noted that there certain aftermarket parts and their effects on the RSX Type-S are mentioned (Jackson Racing's supercharger, Greedy's turbo kit, etc.) but do not necessarily yield the same results on their Civic Si counterparts. To Hondata, I understand that the some of the information on here may not be completely accurate as the Civic Si and the RSX Type-S, although similar, are still different. Any corrections or additional information you'd be willing to include will be greatly appreciated.
General Tuning Issues
Goals of tuning:
- The overall goal should be having educated customers: they should know what to expect from tuning and not have unrealistic expectations
- Reliability is important: always know what is safe and what isn’t, depending on the project
- Repeatability of runs (know all the factors that affect it; synthetic gear oil, for example, takes longer to warm up, water temp, air temp, etc.)
- Maximum power is really only “marketing power.” A complete tuning package also includes easy starting, steady idling and good drivability.
- Road tuning is just as important as dyno tuning; the dyno only tells part of the story and real world conditions are very different.
- Part throttle is very hard to tune (and also to sell as it takes much longer!)
- Tuning for economy/emissions. It IS possible to have BOTH power AND economy. Same for emissions.
Some points to consider:
- A road car is at WOT (Wide Open Throttle) only 0.1% of the time and part throttle 99.9% of the time.
- Part throttle tuning takes much longer (and costs a lot more), but done right makes for much better responsiveness and fuel economy. Some of the replacement chips out there only go for WOT top power. Some of those chips are very specialized, offer no ignition control, and generate error codes. Simply switching those codes off is not a good thing.
- Psychology of VTEC: The VTEC “kick” really shouldn’t be there if the engine is well tuned. Then the curve should be totally smooth. Interestingly, some people think the car with the VTEC “kick” has more power when, in fact, it has less.
Does more peak power always mean faster?
No! Acceleration depends on the power under the dyno curve. Higher peak power can actually generate less acceleration than a car with less peak power. Torque matters! More power between 3,000 and 6,000 is extremely important. The only time when that may be different and peak power becomes an issue is in drag racing.
Reliability:
- How high do people rev? Some said as high as 10,500. This is hardly ever needed as power drops off with most cams well below that. Hondata usually sets the rev limit about 500 rpm past the power peak. That way when you shift you drop back to a good high rev point, but one with lots of power left. How high should you rev? That depends on the strength of the rods and pistons. And valve bounce can damage pistons.
- Don't set the rev limiter any higher than 8600 rpm on a stock engine.
- Running rich/lean? Proper rich/lean tuning is extremely important. An interesting point: the Mugen thermostat and similar do not let engine ever warm up all the way so that tuning gets harder because the engine keeps adding fuel.
- Ignition advance knock: If the spark is fired too soon, the piston is still coming up and the flame front bops into the piston. That can mean broken rods, worn bearings, or blown head gaskets. Sacrificing the last 5 or 10 hp in a highly tuned engine will greatly increase longevity.
- Knock: one problem is that knock sensor reporting to the computer is not very good and the computer isn’t well equipped to accommodate. The knock sensor is actually a microphone; you can put headphones on and hear the knocking and which cylinder knocks.
- Altitude: table columns 1-10 must be tuned for higher altitude operation
- Fuel pressure: Some people think higher fuel pressure is better. That is not always so. Low pressure means cooler fuel, pump and injectors. Some pumps actually move lower volume at higher pressure. Basically, higher fuel pressure does not appear what Hondata recommends. 50-60 psi is the max Hondata recommends.
Dyno repeatability
- Water temperature should be 180-195 degrees
- Use datalogging during dyno runs
- Gearbox must be warmed up, especially when you use synthetic oil
- Keep the intake temperature as consistent as possible or else the dyno results will be distorted
- The intake manifold is aluminum and heats up when it really should be cool. The intake manifold is NOT a heat sink and the gasket does NOT hurt. Bypassing the heating on the throttle body (really only needed in colder climates) amounts to perhaps 20% of the lowered temperature and the Hondata intake gasket 80%.
- Do not switch off the knock sensor nor primary O2 when tuning the Civic Si.
Tuning for torque
- Rough rule: 10% fuel change = 1 Air/Fuel point
- At peak torque engine needs most fuel and is least sensitive (to what?)
- The fuel curve is shaped very much like the torque curve
- After the torque peak, remove fuel
- Don't tune an endurance engine rich
- 2D curves must be smooth over the rpm range (lines in the graph should be parallel and have no sharp drops and rises). Load lines should never cross each other
Tuning for max power
- Use the 2D view extensively to get it right
Stock Honda fuel maps
- They are loaded in the software and you can pull them up
- Study them: The lines are nice and smooth and parallel
Optimize starting and idling
- Cranking ignition does not use the ignition tables
- Idling control opens or closes the IAC
- For bigger injectors increase the target idle
- Advance ignition and lean via emulator
- 750-1000 rpm’s and columns 3-4 are the idle section
- Best idle around 830
Road tuning
- Dyno is different from road and different dynos load the engine differently
- Underhood airflow is different between dyno and road tuning
- WOT air/fuel seems richer on a dyno than on the road, up to a full AF point
- Don’t forget to switch back to enabling closed loop after tuning!
Knock
- The knock sensor is a tuned microphone. You can build one from a speaker amp ($30).
- The Civic Si ECU will not advance / retard on knock
- Knock sounds like a sharp ticking
- The knock counter resets every time the engine is started
Economy and emissions
- Part throttle ignition advance is optimized for economy, best not to change. Also, do NOT lean out the part throttle and run in open loop for economy.
- Doug mentioned examples of cars that failed to pass with the stock ECU but passed without problems with Hondata
Injectors
- Use saturated injectors (12 ohms) like the new 440 and 550’s from RC Engineering
- Stock Civic Si has 310 cc injectors
- 550 cc injectors at 50 psi fuel pressure can handle approximately 320-350 whp
- The Honda stock fuel pump is good for 250-290 whp
What does Datalogging do?
- Records a large number of sensor values from the car’s ECU and stores the data in a connected laptop computer
- Can be used to adjust fuel to get to proper Lambda values
- Measures intake system efficiency with the MAP sensor that senses air pressure or vacuum in the intake manifold (the ECU uses MAP input as an indication of engine load when adjusting air/fuel mixture and spark timing)
- Shows short and long term fuel trim (computer adjusts short term according to Oxygen sensor readings to a long term fuel trim value over a period of time, days, weeks) Watch for bad Oxygen sensors! Resetting the ECU sets the long term fuel trim back to zero.
- Shows intake air temperature compared to outside
- Shows injector duty cycle (should be under 90%). 100% means the injectors always open and cannot supply as much fuel as is needed.
Tuning with A/F ratio
General hints:
- Use a COLD AIR INTAKE! Something like the T1R Intake has better flow and is better than the stock airbox, but does not perform as well as a CAI.
- Use the Hondata heatshield gasket to keep the manifold from heating up and also to help it cool down quicker.
- Insulate/wrap your intake to keep air as cool as possible
- A CAI can provide an additional 0.3-0.7 psi more boost. Hot air costs boost pressure.
- The JRSC needs very little ignition timing retard vs. stock
- Turbo retard 18-20 degrees from 12 psi up
*Erick’s Racing 9.99 second ¼-mile Civic that has 300+ wheel hp on a 2.2 liter engine with the stock ignition and 10,500 rpm limit.
What did Hondata find when they analyzed the ECU?
- The stock Civic Si ECU does not run rich at high rpm
- The Civic Si stock ignition timing is not conversative
- It is VERY sensitive to the knock sensor
- Once tuned, there is more power, yet the same or better emission, and better economy.
Basics: What makes power?
- The motor is really an air pump
- Put in as much air as possible
- Add proper fuel and ignite it at the right time
- Make sure exhaust doesn’t restrict
- Simple as that!
The iVTEC system of the Civic Si is a combination of VTEC and VTC. VTEC basically creates one camshaft profile for good low end drivability, torque and fuel economy, and a second more aggressive “wild” camshaft profile for high end power (the “low speed” and “high speed”). VTC rotates the camshaft by a total of 50 degrees which results in different valve opening overlaps by changing the relative timing between the intake and exhaust valves. Both VTC and VTEC use oil pressure systems controlled by the ECU. The combination of VTEC and VTC enhances the effectiveness of VTEC and offers great tuning opportunities, especially smoothing the midrange and adding power there.
VTEC = Variable Valve Timing Electronic Lift Control
- VTEC is a system that changes valve lift, timing and duration; it’s like having a low rpm and a high rpm camshaft
- A hydraulically operated rod either engages or disengages on both intake and exhaust valves in the Civic Si
- Engaged means the car opens and closes both valves fully (with higher lift via more aggressive lobe), allowing much better breathing (and power)
- The “VTEC Point” can be set at a certain rpm, or it can be set between two rpm points depending on vacuum. The engagement then moves linearly between the two points.
- (Interesting factoid: overhead cams were created to eliminate rocker arms; yet Honda uses a rocker in an overhead cam to facilitate VTEC)
VTC = Variable Timing Control (rotating cam)
- VTC is a system that continually changes intake camshaft timing by a total of 50 degrees
- Why? Because different cam angles provide different power at different revs; switching angles can make for an optimized composite curve
- VTC enhances the effectiveness of VTEC
- What VTC varies by changing the angle is the intake valve opening overlap
- There is a VTC actuator controlled by the ECU that monitors cam position, ignition timing, throttle position and then advances or retards cam over a 50 degree range
- There are advance and retard chambers in the actuator wheel that cause a wheel inside the cam pulley to turn and thus turn the cam
- The idea is to have different cam settings for maximum power and/or lowest emissions; in general: the higher the advance the better the breathing
- Cam is almost fully retarded (no overlap) at idle. This makes for a smooth idle
- Cam angle is advancing as rpm rises, thus opening intake valve sooner to allow additional overlap for better fuel economy due to less pumping losses
- There are 5 fuel & ignition tables for low cam & 5 for high cam (0, 15, 30, 40 and 50 degrees respectively)
- The VTC Control valve and actuator engage and disengage a lock pin
- It takes about 0.1 seconds for the cam to turn by 10 degrees
- Exhaust cam is not under computer control. There may be benefits to adjusting the exhaust cam.
Properly setting and manipulating the cam angles is the most important aspect of tuning the K-Series engine. Basically, what Hondata does dyno runs with the cam angles fixed and see what cam angle produces the highest power at each rpm range. Then they built a composite cam map where the cam is at the angle that produces the highest power at each point of the rpm curve.
The FlashPro Manager software has datalogging built-in.Some of the handy “Parameters” settings of the FlashPro Manager software are:
- For tuning, turn off closed loop because you want to be in open loop so that ECU doesn’t constantly compensate
- Knock: “K. Count” is in the Sensors list and shows how often computer felt the engine knocked. Knock is a stored value, long-term. You can go see where the knocks occur and then see if the AF ratio is okay. If so, then check ignition advance. There can be dozens or hundreds of knock counts in a second (zoom in to see closely).
While the variable cam timing is terrific for tuning, having a constantly moving cam also means that it takes a longer time to tune all this. Doug has explained that when tuning a car and developing the optimal calibrations, they actually do dyno’s at each angle then see what cam angle is best for maximum power at each rpm. Doug has shown high-speed WOT dyno graphs for each cam angle. In general, between 3000 and 6000 rpm, the larger the angle the better the power. However, between 1500 and 3000 different angles produce best power, and at high rpms also.
General procedure for from-scratch tuning of the K-Series engines
- Set ignition timing to stock
- Set VTEC high (6500-7000 rpm) to tune low speed cam
1. Set both cam angle tables all to zero degrees and dyno tune ignition and fuel tables
2. Repeat dyno tuning of ignition and fuel tables with both cam tables all set to 15, 20, 30, 40, 50 degrees
3. Analyze dyno curves, then set cam angle table at each rpm to angle with best power
4. Dyno again with new composite curve (you may want to “bracket” by a few degrees up and down to see if optimal)
- Set VTEC low (2000-3000 rpm) to tune high speed cam, and repeat above procedure
- Set the VTEC crossover RPM
- Part throttle also needs to be tuned (part throttle = columns 7 and lower)
1. At part throttle/cruising (columns 2-7, 1500-4500 rpm) cam angle should be around 30 degrees. This will use EGR effect to reduce emissions and improve fuel economy
2. At higher rpms in part throttle, set angle to same as full load so that cam angle won’t go down during shifts.
3. 500-8100 rpm’s and columns 1-2 are the deceleration sections of the map and prefer lower cam angles (cam lobe centers are separated, valve overlap is minimal and there is little contamination of intake fuel going into the exhaust system).
Proper tuning at the VTEC point and setting the VTEC point
Getting the VTEC point right, and setting the cam angles at the cross-over right, is very important and one of the most difficult tuning tasks. If not done right, the curve is bumpy and performance suffers. This can happen when the low speed cam angle at the switch-over is far apart from the high speed cam angle, so that the cam needs to rotate by a lot. This can result in a power dip for a few hundred rpm after VTEC while the cam rotates into proper position. As for where to set the VTC point, it should be at the intersection of the low speed and the high speed torque curve.
- Cam takes 0.1 seconds to rotate 10 degrees, so you have to start rotating the cam angle before VTEC so that the low cam and high cam angles are not far apart at the VTEC Point
- Done right, the VTEC switch noise is greatly reduced; the difference in noise is because when VTEC engages you’re really running a different engine
- It’s better to sacrifice a bit of power before the VTEC point to gain it back and more after VTEC
- Getting the VTEC Point right is hardest to do on turbo motors (they generally want a high VTEC point)!
For NA engine tuning:
- Cam advance should be biggest (50 degrees) right after VTEC Point and then all the way up to 6500-7000 rpm
- After 7000 rpm, gradually take cam angle back to 25 degrees at redline.
- In general, with high backpressure you should retard the cam angles and raise the VTEC point, with low backpressure the opposite
- Use variable VTEC window, with lower boundary at point of highest power (intersection of low-speed and high-speed torque curves) at 90 kPa and upper boundary at 5,800 at 25kPa.
- The longer the primary and secondary runners on a header the lower the VTEC point.
- Air/fuel ratio that makes best power at WOT under full load is 13-13.5
For turbo VTEC tuning:
- If your cam angle is ever 0 at 8000 rpm, you have a major exhaust restriction which needs to be looked at.
- Retarding the cam can mean picking up 40 horsepower at high RPM.
- Use a fixed VTEC point. Since the crossover is high, the VTEC point should be high, around 6,000.
- However, a tubular turbo manifold setup may need a VTEC point of 4000-4500 rpm.
For extreme cams, add lots of timing at low end for impressive torque gains, raise idle speed, reduce overlap in part throttle.
Supercharged engines:
- Tuning is really similar to larger NA motor.
- Supercharged engines love overlap (high cam advance)
- High cam set to 50 degrees throughout most of rev range, then down to 40 from 7000 rpm on up
- Low cam VTC 45-50 degrees
- Cam angle actually affects boost in manifold
- Don't set the WOT closed loop higher than 90 kPa.
- The higher the RPM, the higher the boost. (Greddy turbo actually got less boost at higher RPM)
- In the fuel tables, boost curves should be very flat and smooth
- However, more boost does not necessarily mean more power
- Ideal A/F ratio at WOT under full throttle is lower than NA, 11.5-12.5
- Use variable VTEC window like on stock engine but with two exceptions: you can set the lower boundary lower, down to 3,000, but set both the lower and higher point to occur at full engine load pressure. That way there won’t be a linear line. Under load it goes into VTEC, under part load it goes out of VTEC once revs fall below the upper boundary.
Nitrous:
Doug said the use of nitrous was much safer with the FlashPro. He recommended a dry system. Wet nitrous system are not a very happy match with Civic Si because at redline, the Civic Si cuts off fuel whereas nitrous continues, instantly leaning things to catastrophic levels. Nitrous works quite well with boosted engines. They get higher boost (by about 0.5 psi) and the supercharger acts as a nitrous mixer. Hondata tried a JRSC with 7 PSI and N2O. The nitrous dry system added boost but they found the belt slipping at high RPM (Doug runs DC twin canister exhaust and 7psi on his car). Ignition should be retarded, the system needs larger injectors, and nitrous should be shot off before redline. With turbo engines, nitrous can reduce turbo lag by spooling up the turbine more quickly.
Tuning for intakes:
For tuning purposes it is important to know the resonance point (the rpm where the intake makes that extra sound as if you were blowing on a bottle) of a CAI. For example, the AEM CAI on an RSX-S has a resonance point of 5200, the short ram AEM V2’s is at about 5900. Longer pipes have lower resonance points. There is a torque peak (and often a lean spot because an untuned motor doesn’t get enough fuel) at the resonance point. You can tune for different intakes. Doug has mentioned that pressurized intakes can really make a difference. Build a box around it to force air into it.
Intake manifolds:
Doug has shown some dyno runs of stock Type-S versus the Integra Type R intake manifold which has slightly fatter runners, and so should do better. However, the horsepower difference is primarily at the high end where the Type R peaks at higher rpm.
Fuel cooling and such:
Theoretical contemplation on injector positioning: They should be at the top of the runner. This would be bad for emissions but good for power. Doug has spoken of the power benefits of cooling fuel. 20 degree Celsius difference means 1% more power.
A variety of tuning pitfalls:
- Valve spring pressure too high is bad news as there isn’t enough lubrication.
- Cams can be installed incorrectly.
- TPS and MAP sensor can be reversed.
- The MAP was not relocated in a supercharger installation. (It must be AFTER the compressor.
- The supercharger belt can be slipping
Effects of various mods:
A stock K20A2 engine makes between 160 and 175 wheel hp. That is quite a big difference in a modern precision engine and it could be because of different sensitivity in knock sensor. Doug went on to show dyno sheets of a variety of mods they added to a stock motor.
A Hondata reflash added almost 20 hp on top (the primary benefit is the mid range power), an AEM CAI another 10 to about 190. A Greddy catback exhaust added a bit and ITR cams another 15 hp. Raceheaders from Comptech added an impressive 15 up to almost 230. A ITR manifold boosted the high-end a bit and placed peak power more into the 8000s. Titanium exhaust and pulleys added a few hp but not much. Finally they installed a ported big valve head with Toda cams, for a result of almost 250 all-motor whp. Hytech exhaust, 12:1 pistons, cams and intake raised that figure up to 270.
Another project (Hasport/Jackson Racing Civic Type R) replaced the K20A2 bottom with a K24 CRV bottom. This brought 40 pounds extra torque, but power dropped off quicker at the high end. Initial peak power was 210 whp. They added an 8psi JRSC and got torque of over 230 foot-pounds and over 290 whp.
K-Series Bang-for the buck list of mods (least to most expensive):
- Intake Gasket
- CAI
- ECU Reflash
- Header/Exhaust
- FlashPro and tuning
- Cams
- Nitrous and boost
- K24 bottom end swap
tb144050
Post by tb144050 »
wow...55 views and no one has posted a single word on here...or any of my topics for that matter. Does no one stop and join this site? Just search, read, and move on? :( Every man for himself?? Selfish people...lol
--TJ
ITR1102
Post by ITR1102 »
tb144050 wrote:wow...55 views and no one has posted a single word on here...or any of my topics for that matter. Does no one stop and join this site? Just search, read, and move on? :( Every man for himself?? Selfish people...lol
--TJ
A lot of this stuff is easily sourced elsewhere, as well as on Hondata's website (not forum). They have a couple different tuning guides and a lot of good info. And why post K series tuning info in this S300/SManager thread? People with K motors aren't going to be using an S300.....
tb144050
Post by tb144050 »
ITR1102 wrote: A lot of this stuff is easily sourced elsewhere, as well as on Hondata's website (not forum). They have a couple different tuning guides and a lot of good info.
answer:
tb144050 wrote: The purpose of this very thread is to be the GO-TO-POST place for all the noob questions!! I, along with thousands of noobs, have had millions of questions over the last ten years...yet there is still no indepth tutorial/walkthrough for complete noobs. So here is the place to post the questions we all have, but are too embarassed to ask.
The general idea is to combine info from all the other scattered sources into this one thread. Hopefully, after a future noob reads this thread from start to finish, it will answer questions he/she didn't even know they were about to ask (and then be told to "search for their own answer".
ITR1102 wrote: And why post K series tuning info in this S300/SManager thread? People with K motors aren't going to be using an S300
Sorry. Me being a noob and all, I didn't catch the incompatibility. However, I will consider removing the NON-s300 info if I determine that it is not useful as an example of basic tuning info and potential results.
If you have valuable input that you wish to share with beginners, please assist us by posting it. :)
civic EK sir
Post by civic EK sir »
Great thread. Useful information from great author.
Thank.
