P0132 O2 Sensor Voltage High - K20 swapped EG
Posted: Thu Sep 22, 2011 2:31 pm
by playasyougo
Hi,
I've swapped a Euro K20A2 into a JDM Civic EG6 and i'm getting this error code and i'm not sure why.
I've replaced the O2 sensor for a new item and i still get the error.
Has anyone ever come across this?
If not, what where would be a good place to start to find out the issue?
Re: P0132 O2 Sensor Voltage High - K20 swapped EG
Posted: Thu Sep 22, 2011 3:14 pm
What ECU are you using and what o2 sensor are you using?
Posted: Thu Sep 22, 2011 4:48 pm
by playasyougo
Spunkster wrote:What ECU are you using and what o2 sensor are you using?
PRA KPRO
Honda O2
Hasport wiring harness
Posted: Thu Sep 22, 2011 4:55 pm
Honda O2 is not very specific. What is the Honda part number?
Posted: Fri Sep 23, 2011 7:31 am
by playasyougo
Spunkster wrote:Honda O2 is not very specific. What is the Honda part number?
Sorry, I cant quote you the part number just now but it's new from Honda and was the same number as the O2 i removed and originally tried from the donor Euro Civic Type R i got the engine from.
Posted: Fri Sep 23, 2011 9:24 am
Posted: Sat Sep 24, 2011 3:01 pm
by playasyougo
Sorry, i will gather all this information and put it in the post.
Posted: Fri Nov 04, 2011 3:58 pm
by playasyougo
Update!
Managed to fix the issue.
On the Hondata page here shows the changes necessary to run the US ECU and oxygen sensor - http://www.hondata.com/techk20-ctr-o2wiring.html. Owning a UK ECU i never took note of this as it mentions pins A16 to E4. The UK PRA ECU doesn't have a pin going to either so all it took was getting some spare pins and fitting to both plugs and that was it. No more fault codes.
Just to confirm this is a UK K20A2, PRA KPro, Hasport harness, Civic EG.
Posted: Wed Jul 04, 2012 1:34 pm
by playasyougo
Better update.
Should have added this in sooner. The above fix never actually worked but the comment at the end of this thread did get rid of the P0132 error code. It's never appeared for months and months now.
http://www.hondata.com/forum/viewtopic.php?f=12&t=13226
