Hello,
When at idle and I blip the throttle the rpm drops and then go for the correct value, if i press the throttle deep this issue doesn't happen. Does anyone have this same issue?
This starts a week ago or so..
RPM drops
Tsuchinoko
RPM drops
Those who know don't tell, and those who tell don't know.
Re: RPM drops
Check for TPS voltage when TPS is closed. Should =0.5v
Post your map and log.
is your engine stock?
What is the IACV duty cycle?
Tsuchinoko
Re: RPM drops
Yeah i'm thinking on the TPS too, later i will see the voltage.
Thanks for the reply.
RPM drops
Tuning Issues
1)Also cud be a/f ratios, if u are using high-cams. a/f in the idle and off idle need to stoichiometric or slightly richer
2) ignition timing - see the help on the hondata site - advance timing as needed.
3) in the latest version of hondata u can set the fuel recovery rpm (overrun fuel resume) under Parameters>TPS
4) also increase the IACV duty cycle
Hardware Issues
If your car is stock and u r using stock maps, it likely to be a hardware issue (idle screw, TPSv, IACV, wiring). clean your IACV. does yr car have air-con? does the ACCL and stator spin with no drag? ACCL bearing OK? Old Car?
Hardware Issues
Tsuchinoko
Re: RPM drops
Thanks you are really a helpful person.
But it was the TPS calibration. In my car it works ok if the reading is between -1.20 / 0 on 0%
and it was on the -2 range.
Now is ok unfortunately i think my TPS is not in very good shape, it changes a lot, is the way i release the pedal, if i release smoothly it reads 0 but if i release quick it may read ~-0,9%.
That's why i have some issues on idle.
Thanks once again ;)
Regards
Regards
