Page 1 of 4
KManager V3.0.3
Posted: Wed Sep 14, 2011 8:30 am
This release mainly contains changes to update the KManager for the KPro-III
Changes:
  • KPro III support.
    See KPro-III This includes a new 'KPro' window, which replaces both the 'Datalog Download' and 'KPro Information' windows.
  • Improved datalogging/recording performance when display window is maximized.
    When the display window is maximized, other windows are not updated, which gives an increase in datalogging performance.
  • Fixed the relative adjustment function for Lambda using AF ratios.
  • Fixed launch control max speed range.
  • Fixed tabs in the settings window.
  • Added automatic conversions to sensor display minimum and maximums, and also sensor warning minimums and maximums.
  • Added functionality to save window position with multiple monitors.
  • Included security check to prevent saving data to the Program Files directory to avoid virtualization problems with Windows.
  • Added Import/Export feature to the Sensor Settings form, the Graph Template form, and main Settings form.
  • Added speed correction to the Parameters for under Misc.
    Now speed correction can be used for the 02-04 RSX, as well as the 05-06 RSX. Note that the 02-04 speedometer does not receive the speed from the ECU, so cannot be changed.
  • Added a driver check entry to the status bar, a balloon hint to install the driver, and a check box to disable the balloon hint.
  • Added 2D graphs to the small tables in the Parameters form.
  • Modified the exception report form to directly email reports to Hondata instead of populating users' email service.
  • Improved 05-06 speedometer behavior.
    We have made a change which we believe will help speedometer consistency for the 05-06 RSX.
3.0.2 Changes:
  • Fixed TPS showing -1%.
  • KPro III digital input added.
3.0.3 Changes:
  • Fixed registration for early KPros.
  • Improved handling of screen scaling under Windows 7.
Notes:
  • KPro-III Analog Inputs
    Analog input settings are saved both in the calibration and to the KPro itself. The KManager sensor list is updated from the KPro when datalogging or recording is started. Datalog recordings made from the KPro also include the analog input information. In this way, analog input details (like name, type and units) are saved and transferred without the necessity of entering in analog input information for each different KPro or datalog.
  • KPro-III Digital Input
    Serial numbers below 10049 will need to send in their KPro if they wish to use the digital input.
Re: KManager V3.0.0
Posted: Thu Sep 22, 2011 8:10 pm
by NtegraDryvr
With Kpro v3 or with the Kmanager update does that give us the ability to datalog the OEM wideband and an aftermarket wideband like an AEM at the same time while retaining the closed loop & wideband functionality?
Re: KManager V3.0.0
Posted: Fri Sep 23, 2011 7:50 am
Yes, if the aftermarket wideband is connected to an analog input.
Re: KManager V3.0.0
Posted: Fri Sep 23, 2011 8:38 am
by NtegraDryvr
Very cool I am happy to see this. Will it only work with Kpro v3 or just with the new kmanager and the aftermarket wideband hooked up to the ELD like the old kpro allowed for datalogging?
Re: KManager V3.0.0
Posted: Sat Oct 01, 2011 4:40 pm
by Bard
TSX K-Pro dual harness also can be upgraded ?
Re: KManager V3.0.0
Posted: Sat Oct 01, 2011 5:23 pm
by akep
tried to download map from 1.5.1 ecu with kmanager 3. had a bit of trouble and like 100's of error windows popped up. this happened more often than getting a successful download, but i got it.
should also make a way to save the ecu registration and be able to register the ECU when you are able to get internet (reg file), instead of having internet at the time of registration. the shop i work at didn't have wireless access so i had a customer waiting for us to figure out the new kpro ecu.
other than that the ecu works awesome. fresh uploads and downloads from a kpro 3 ecu are lightning fast. kmanager 3 also looks updated a bit.
Re: KManager V3.0.2
Posted: Wed Oct 05, 2011 4:31 pm
Comparison of AF from stock o2 sensor, PLX wideband (analog) and PLX wideband (digital).
Stock wideband is fastest, doesn't read below 11.5:1
PLX digital output is only 10 Hz so significant quantization occurs.
Re: KManager V3.0.2
Posted: Fri Oct 07, 2011 12:32 pm
by hardcorersxs
Is there any development to make lean protection work with the launch limiter without disabling lean protection? Adding a setting to where lean protection is enabled for vehicle specific speeds (i.e. having it come on only when the mph reaches 1mph and 100% tps and/or certain load settings would be of great help.
Excellent work on the new beta. Looking forward to the official release version.
Re: KManager V3.0.2
Posted: Fri Oct 07, 2011 4:41 pm
First time I was aware of that issue. Will add it to the list. Also we plan to add a burnout rev limiter.
Re: KManager V3.0.2
Posted: Sat Oct 08, 2011 1:27 am
by hardcorersxs
thank you Doug/Derek/Hondata team. Hope all is well
Re: KManager V3.0.2
Posted: Sat Oct 08, 2011 11:41 am
by The Spectacle
Bug: Under Kpro -> Registered Owner the "About Registration" hyperlink goes to Knock Control in the help file
Re: KManager V3.0.3
Posted: Mon Oct 24, 2011 6:28 pm
by akep
Can't get Advvanced Parameters to show up? just greyed out..
Re: KManager V3.0.3
Posted: Tue Oct 25, 2011 9:18 am
Do you have a calibration loaded?
Re: KManager V3.0.3
Posted: Tue Oct 25, 2011 10:36 am
by tiger
Will (can) there be an update that lets us change what a/f ratio we idle at in closed loop? Last time I checked, no matter what you do, if it's in closed loop it's idling at 14.6.
Re: KManager V3.0.3
Posted: Tue Oct 25, 2011 11:12 am
Parameters -> Idle -> Target Lambda
