Hello ,
Advice needed for my cams angles and ignition on boost :)
My setup k20a2 stock,rbc im ,exhaust full 3'' ,t3t4 ar63 ,boost 8 psi , rc750cc,ngk8
I'm not sure my angles cam are the best on boost ? Do you have any advice?
Advice Needed for my Cal , Boost 8psi k20a2
Re: Advice Needed for my Cal , Boost 8psi k20a2
Hello ,
In my local dyno test the car had 291 hp with 7.5 psi max 11.4 to 11.6 afr
