specs are as folows
b16b engine,
stock pistons/rods
crower sage 3 N/A camshafts
TWM ITBs, with 50 mm. bodies. (also has its own TPS)
aem adjustable cam gears
blaster ss coil
440 cc injectors (high impedence)
i was told the itr stock calibration may work. if thhe is a way to change its settings to match a b16b, your input would be greatly appreciated.
-kick
need B16B basemap and/or calbration
civic EK sir
Re: need B16B basemap and/or calbration
Hi kick
Since you have ITB the MAP sensor will not help .you need to do these change in TPS under table lookup select TPS
and start tune the car with wide band you can see help in hondata Tuning ITBs
itr stock calibration will not work it use map sensor
best regards
best regards
seth.mcdaniel
I have a tune for lsvtec with twm itbs. Ill try to find it. Do you have an email I can send it to?
