Idle issue, no power, cel vsc light on...
Posted: Tue Sep 06, 2011 10:00 pm
by civicmatgsr
I have a 04 TSX with dual ecu, and a kpro number around 5000068.
The problem i have, the idle is good when it's cold, but when hot, 1000-2000 rpm up and down.
I canot get above 3000 rpm with full throttle. I have unplug the DBW on the throttle and don't change, unplug the map and engine stall.
I don't have the map and i don't be able to download it from ecu.
Want can cause that?
Re: Idle issue, no power, cel vsc light on...
Posted: Wed Sep 07, 2011 9:29 am
What is the exact serial number of the K-Pro board inside the ECU?
Posted: Wed Sep 07, 2011 1:12 pm
by civicmatgsr
Kpro is 5000069.
I found my problem, the D conector is plug in the harness insted of the tsx ecu. My fault.
The traction control seem to not working.
Another question:
If i had another kpro 5004800 with dataloging, can i swap it with the 5000069 ?
Posted: Wed Sep 07, 2011 4:51 pm
That serial number was not designed to be used with our dual adapter setup which is discontinued. We do not support swapping K-Pro boards from one ECU to another, especially in a non-supported TSX dual adapter setup.
Posted: Wed Sep 07, 2011 6:34 pm
by civicmatgsr
If the 2 kpro i have are not to use in a tsx, what issues they can cause ?
The traction control is not supported coretely ?
Can i get 1 of my 2 kpro to a hondata retailer to get the good set up ?
Posted: Sat Sep 10, 2011 12:25 pm
by civicmatgsr
Spunkster wrote:That serial number was not designed to be used with our dual adapter setup which is discontinued. We do not support swapping K-Pro boards from one ECU to another, especially in a non-supported TSX dual adapter setup.
Here is the ecu.
#37820-PRB-A05
2068-509258 0E14
I don't have the map and i don't be able to download it from ecu. I have try to download but it not work.
Kmanager v 1.4.1.0
Posted: Sun Sep 11, 2011 6:03 am
by mkulak
You could use the K-Tuned Harness but would not have VSA functioning.
http://k-tuned.3dcartstores.com/Dual-EC ... _p_25.html
PM me with your setup and I might be able to help you with a file to run your car. I've got a few different .kal files from different setups on my TSX.
Posted: Tue Sep 13, 2011 6:27 pm
by civicmatgsr
Thanks, but the car is running, but it can't be tuned, until i can be able to try to upload a map, and if it din't work the car will don't be driveble until the dyno day.
Spunkster tell me the ecu is not desing to run dual ecu but don't help me after that.
Need suport from Hondata HERE.
