flashpro 1.1.8.5
honda_racer07
flashpro 1.1.8.5
Post by honda_racer07 »
Every since I download this new version 1.1.8.5 when I upload an adjusted calibration it tells me:
last upload failed, last upload slot primary.
I can't seem to correct the problem. How do I either fix this problem or go back to the last version of software I still have?
Re: flashpro 1.1.8.5
What type of upload are you performing? What is the exact error message (provide a screen shot if possible)?
honda_racer07
Sorry for the long delay but here's the code that I got last upload failed:
Code 0x00 step 20 address 0x000000 memory problem
I had only made some changes to my throttle position map and went to upload that's when I got this message. Seems to me that all of my datalogs have been updated to the new software. anyway let me know how to proceed to correct this problem.
Thanks!
Try uploading a different calibration to the ECU and see if that works.
honda_racer07
Uploaded a new calibration no problem it's when I flash it to the vehicle I get the same code everytime.
Can't I just rollback my maps and calibrations to the last version of software I had no problems before I uploaded this new version.
Please use the 'send support information to hondata' function from the help menu.
honda_racer07
I sent over my info a couple of days after your last post and still have gotten no response, no follow up nothing from the tech support department. Today I sent my complaints again as this has been going on for nearly a month now I would appreciate some follow up on this matter.
Please download the most recent beta versio of software from the downloads section of our website and see if that resolves the problem.
The FlashPro is not uploading because one or more of the pins in the OBDII connector are bent or missing. It also could be the wiring between the OBDII connector and ECU, but most of the time it is the pins in the OBDII connector.
honda_racer07
Shouldn't I be seeing a message about the wen? I did have this happen once. The message I get now is about the memory.
honda_racer07
I did download the new beta per Matt and still have the same issue. Once plugged into the vehicle depress program, red light comes on 4-5 sec. Does not start blinking or the process of uploading. Lights then turns off and stops process.
The support information you just sent showed an error with the WEN (write enable) pin in the OBDII connector. Check this first.
honda_racer07
Ok will do
