for a turbo gsr
Posted: Thu Oct 03, 2002 9:28 am
by TuRbOgSr818
i was wonderin if anyone have a fuel map for a turbo gsr vafc, mods are:garret t3/t4 hybrid,fmu,msd,holly fuel pump,tial wastegate,build bottom end with piston and rods,profec a.
Posted: Fri Oct 04, 2002 9:37 pm
by Carchitect
When you have a vehicle as modified as yours there is really no set maps that will be accurate. There are just too many variables to take a chance on. There are a few known good tables in the ROM editor that will be good start but they will require the wideband to adjust the fuel tables and the timing will need to be adjusted on the dyno. These are both very very important. The end result will be very exhilarting but will require some work.
Based on your mods. You're probably running in excess of 15 psi boost so I would run 720 cc injectors to be the minimum.
