ignition
Posted: Fri Aug 26, 2011 10:47 am
by danno
Have searched already but didn't find anything specific
What can cause kpro to not see the ignition turn on?
Re: ignition
Posted: Fri Aug 26, 2011 11:11 am
It is usually a wiring problem or a damaged ECU from a wiring problem. Try the ECU in a known good vehicle.
Re: ignition
Posted: Fri Aug 26, 2011 11:26 am
by danno
I will try that tonight and repost
Can I have a ecu sent in and repaired?
Re: ignition
Posted: Sat Aug 27, 2011 5:27 pm
by danno
ecu works fine, are there any certain wires or particular relays to check? ive checked all the fuses under hood and dash
vehicle is 2005 civic si, had kprod back in 06
oem harness but dash was removed and non necessary items removed heat etc.
Re: ignition
Posted: Mon Aug 29, 2011 1:37 pm
Look at the wiring you have changed, something has been done incorrectly.
