noob help
Posted: Wed Aug 24, 2011 5:56 am
by coperfil
hi there if you look at these logs and helping me to find any problems in my car is not going well, thanks.
Pd. sorry for my English translator
Re: noob help
Posted: Thu Aug 25, 2011 5:07 am
by coperfil
have some value if someone is wrong in the log and I can help solve the problem
Re: noob help
Posted: Thu Aug 25, 2011 7:41 am
by sc0rcher
U need to do a 3rd gear WOT pull to see how yr car behave in open loop.
Also u need to fine tune yr AFM calibration and ignition and position where there is high retard.
My 2 cents..
Re: noob help
Posted: Sun Aug 28, 2011 1:09 am
by coperfil
new log
Re: noob help
Posted: Sun Aug 28, 2011 6:36 am
by sc0rcher
Hi, i think you got a same problem with my car... u are getting knocks at fairly low ignition advance, which drives yr knock control crazy and the ign advance is retarded by a hell lots... Maybe u would like to post yr calibration here...
My car is also getting a hell lots of knocks at fairly low ignition advance, and i guess it's some engine problem. Maybe u would wanna check yr motor also...
@Hondata, any advise?
Re: noob help
Posted: Wed Aug 31, 2011 10:37 am
by coperfil
nothing?
Re: noob help
Posted: Thu Sep 01, 2011 6:28 am
by skier
there is nothing wrong with ur car.
every instance that the knock is appearing, either u apply a sudden full throttle that cause the engine to jerk. or a sudden change of throttle.
ur knock count is too low to be concern about.
Re: noob help
Posted: Thu Sep 01, 2011 9:41 am
by sc0rcher
I am not sure of this, but from the datalog showing knock level of up to 19% at idle is abit high in my opinion.
And driving at WOT at ~2500 rpm with ign advance of sub 10 degree, the car is obviously not pulling power.
Just my 2 cents..
Re: noob help
Posted: Sat Sep 03, 2011 1:54 pm
by coperfil
ok thanks for the responses, and burn a lambda sensor and put new ... so you have a problem
