D16y1/D16z6 won't idle after engine swap.
Ben92
Post by Ben92 »
Hey guys,
Recently did an engine replacement on my EG hatch
D16y1 running Hondata s300
High flowed injectors
Bosch 044 fuel pump
t04e turbo setup w/ ext gate
etc etc
Seems it would not run with the old tune map it had on the car before the new motor was fitted (will not idle/seems to misfire - unsure why). I have since just ran a base map so the car is drivable. However because of this it is not tuned for boost and will hit boost cut at 1psi.
I can't get the car in for a tune till late next week. Anybody have any decent turbo d16y1/z6 maps for a similar set up that I can run until the car is tuned?
Or perhaps any tips/tricks so I can get it running on boost (very low boost, say 1-3 psi but just so it does not hit boost cut and is drivable on throttle).
