Possible Hondata issues
Bizarre
Post by Bizarre »
Hi all,
I'm having two issues with my car that I believe to be both linked. Let me know what you think.
I'm running Hondata s300 on my boosted application.
Issue 1 (most important one);
When under hard acceleration the car can loose traction and spin the tires. When it does the engine quickly spins up and hits the rev limiter. When it does hit the rev limiter everything shuts off (all power) for a few seconds until I crank the car over again or pop the clutch back up and bump start it. Nothing has really change on my setup and this problem just recently started happening. Opinions???
Issue 2
When data logging and the fan turns on, the logging will disconnect and stop. Anybody have any opinions on this problem? I have a feeling both this issues are linked.
Thanks everyone for your time.
Mike
Re: Possible Hondata issues
Bizarre
Post by Bizarre »
Sorry about that I should have read the sticky first.
Calibration attached
Details:
99 Honda Civic
Honda P28 with Hondata S300
OB2-OB1 Conversion harness
Stock B18C
Injector Dynamics injectors 1000cc
Stock ignition
Garrett 60-1 Turbocharger
Spal pusher fan wired in with separate relay utilizing stock trigger
NGK AFX Wideband with Bosch o2 sensor.
No data logs right now. Will go out tonight and log.
