What does my H22 TURBO need, not WANT, need in order to run?
Posted: Sun Mar 14, 2004 3:28 pm
by h22vtec
What does my h22 turbo need in order to run good for daily driving and a
little bit of street play. Ok, a lot of street play. This is what I got guys and
I am getting mixed input on what to do. I have a 1993 honda civic dx 4dr
with a 97 h22 motor in it that originally had an auto trans, but now has a
manual prelude tranny, I believe the motor is usdm. I think I am running
stock gsr injectors which are 240cc cuz there is no resistor box on my
setup. I have megan racing adjustable cam gears, stock intake manifold
and throttle body, motor is a stock block, head hasn't been touched either.
Running an aem fuel rail with aem regulator. I have a t3o4 hybrid turbo
setup (.48 a/r and .60). Equal length manifold, with tial wastegate set with
a .4 bar spring which is 6lbs and a tial blow off, a spearco style intercooler,
2 step boost controller, 2 inch thick radiator, fidanza lightened flywheel, act
stage 3 clutch, 3 inch exhaust to a 2.5 inch exhaust all the way back. No
cat. The car has just been turbo'd like I haven't even drove it yet, its still
in the shop. Before you flip out about my injectors, I do have 450cc dsm
ones that are gonna be installed along with a low impedance resistor box.
Here's my question, i have a p06 that was chipped to a p13, and im
running hondata s200 with 3step and datalogging. This is a stock motor
and will only be boosting a max of 9lbs if that for now. What do I do for
hondata purposes, do i get the boost option with the 3 bar map sensor,
and extended 6 colomns they add to the fuel and ignition tables, or do i
stick with what i have, since the stock map sensor will read all the way up
to 11 lbs of boost before throwing errors? And whats the best and
cheapest way to get it tuned right? Do i need rom editor
and that
romulator device? Should i just have it taken to a dyno, or have it street
dynod using a wideband? I dont know where to go from here as hondata
is concerned. Please help. My screen name on aim is spoolingpower. Any
ideas are most appreciated. I also have pictures upon request.
Posted: Mon Mar 15, 2004 1:30 pm
by fox30
Get the boost option and get a 3 bar map when your ready to go past 11lbs
>the best and
Locate a Hondata Dealer near you to tune it right.
>Do i need rom editor and that
>romulator device?
Not unless you want to program it yourself, I recommend having a hondata dealer do it instead.
Either or, not that big of a deal. Depends if the dyno machine is a good one. Most arn't. The portable type dyno machines are the way to go.
Street tuning is actually great too.
Call a hondata dealer near you. goto the website and click "Dealers" to get a list in your state or country.
If you are not familure with programming tables, I dont think you want to learn on YOUR car.
Have someone with all the right equipment do it for you. (lambda meter, romulator, programmer, software, experience. Dont mess with your sh** you could hurt yourself and someone else. BOOM
