kpro is not being detected by the labtop
hioutput
Post by hioutput »
kpro is not being detected at all by the labtop, im not even getting it to allow me to update the drivers could it be the cable, the one im using is a one i used from a printer because i miss place it
mkulak
Re: kpro is not being detected by the labtop
Post by mkulak »
Printer Cable - FTL
That is your issue! Whenever I try to tune a car with a non-hondata cabe I have issues. I know keep my Hondata Cable in my laptop bag due to this.
Need a Kpro or s300 Tuned in the Toronto area? Send me a PM.
When was the last time it worked? What has changed since then? What does it show up as in the Windows Device Manager?
hioutput
Post by hioutput »
I just got it about a week or two ago serial#37820-prb-ao7-2068-704039
I bought it for the s2000 it took me a few weeks to get all the sensors installed, Just went to set it up yesterday and i don't get anything.
It doesnt say anything in the device manager, thats why i'm wondering if its the cable. Car is all stock other then exhaust
With the Device Manager open, does the screen refresh when you unplug and plug in the USB cable to the K-Pro?
hioutput
Post by hioutput »
no does not refresh
Try a different USB cable
hioutput
Post by hioutput »
so my buddy came over with his s300 cable and as he was about to plug it in he thought the usb on the kpro looked odd so we went and took his out of his car to check it out and it looks like it has the part in the middle missing
Mine
his
If this is my problem let me know so I can get it fixed asap I received it like this, never even made it to the car
Send an email to support <at> hondata.com with a link to this thread and a detailed description of the problem including the serial number of the K-Pro board inside the ECU.
hioutput
Post by hioutput »
So i get the original box with the bubble wrap that the ecu was sent in so that i can wrap it to send it back, and there is the plastic piece, I say let me try to put it in and see what happens, i put it in hook to my lap top to give it a whirl, and drivers loaded, car is running
The only issue i have know is that the air fuel doesn't fluctuate it stays still at 14.5
That is because you do not have a wideband o2 sensor.
hioutput
Post by hioutput »
I see I was under the impression that it would show you the narrow band readings, unless you told it to read off of a wide band.
Thanks for all your help
ep3_2002
Post by ep3_2002 »
I'm having similar problem. Laptop detects something has been plugged in but does not allow me to load drivers and never detects device as KPro. I've tried several different computers with same result. I've tried forcing PC to load the drivers but it still doesn't show kpro in device manager, just "unknown serial device" or something like that. I opened the case and found that the daughter card was loose. I tightened up the screws (not too tight) but still the same problem. I purchased car with Kpro and I've never been able to connect it to a PC. How do I proceed?
email support <at> hondata.com, include a description of the problem and the serial number of the K-Pro board inside the ECU.
ep3_2002
Post by ep3_2002 »
Will do. Thanks for quick reply.
