Hey All,
I've been running into some problem with getting my car to idle with Hondata provided engine cal for a B18c JRSC 12ohm. I have the correct setup (ie..rc 440cc, fuel pump, w/cat) but my idle is really lean(18:1). After increasing all the fuel cells, I can make it idle around 14.7:1 AFR but is this expected given it a base engine cal setup for my particular setup?
Any Idea?
very lean upon uploading correct engine cal
Re: very lean upon uploading correct engine cal
as a base you will more likely always have to configure it for your setup every engine will respond different no matter what
LGMotoring
IG:Lgmotoring_official
Lgmotoring.com
Lgmotoring.com
