Boost solenoid ecu issue!
Posted: Mon Jul 11, 2011 5:19 pm
I installed the boost controller hardware in my ecu sometime ago and we are now tring to use boost controll option with hondata solenoid, but the car would continually over boost. We found out that with this ecu connected it is leaving solenoid wide open for some reason. Because when I install another customers ecu in my car which I also had installed the boost components into the solenoid seems to be working correctly. So my question out of the components added for the boost control which maybe causing solenoid to be wide open, so as to narrow down the trouble shooting of this? Other then this issue with boost control components the ecu works flawless. I looked over all solder joints everything looks fine other then there looks like some slight heat discoloration on the metal part of the large transistor.
