Page 1 of 2
A/C Air conditioner does not work in AFM mode
Posted: Mon Jul 11, 2011 4:02 pm
by jimmyz98
2009 Civic Si - 2.0L
Hondata Flashpro holds two presets. I set mine up as follows.
Preset 1 - AFM tune
Preset 2 - MAP tune
When I upload the MAP tune, the oil life goes to 100% and the AC works.
When I switch to AFM tune, the oil life goes to 0% and the AC compressor won't turn on.
I reset the oil life and it still doesn't kick on the compressor.
When I switch back to the MAP, the AC works just fine.
Any thoughts?
Re: A/C Air conditioner does not work in AFM mode
Posted: Mon Jul 11, 2011 4:50 pm
Post the calibration you are having trouble with. Also from Help, About, what version of software are you using?
Posted: Mon Jul 11, 2011 5:02 pm
by jimmyz98
I'm using version 1.1.8.5
Thank you for the fast response.
Posted: Mon Jul 11, 2011 5:43 pm
by jimmyz98
ECU = RRB-A14
Flashpro Serial = FP-SI-US-10235
No datalog
Posted: Tue Jul 12, 2011 4:49 pm
we will look into this
Posted: Tue Jul 12, 2011 5:45 pm
by jimmyz98
Thank you
Posted: Wed Jul 13, 2011 8:43 am
Occasionally we have seen the AC stop working temporarily after reflashing. The cure is to go back to stock (using return to stock), power cycle the ignition, and then run the car until the AC starts to work (which may take 1-2 driving cycles, including the idle re-learn). Then load the AFM calibration you want. It only happens to about 1/500 people.
Posted: Thu Jul 14, 2011 4:03 pm
by jimmyz98
okay
Posted: Thu Jul 14, 2011 4:04 pm
by jimmyz98
thank you for your response
Is it the software?
Posted: Fri Jul 15, 2011 8:19 am
It is from the reflash process rather than the FlashPro. I'd suggest picking either an AFM or race calibration and sticking with it.
Posted: Sun Apr 12, 2015 9:24 pm
by af.orozco
Hi, I conected for the fist time the FlashPro via bluetooth to my phone an suddenly my AC stop working.
Following your advice in this forum reflas my ECU to Stock and still no AC.
Do you have a work arround this issue.
Andres
Posted: Mon Apr 13, 2015 8:47 am
See the post above. Go back to stock, power cycle and then drive until the AC starts to work. Of course, it could be a fault unrelated to the reflash process.
Posted: Mon Apr 13, 2015 9:33 am
by af.orozco
Ok, Thanks for the fast response. Did "back to Stock" procedure last night I´ll drive the car to see if it Works.
Will update.
Posted: Sat Jun 20, 2015 1:10 pm
by vtecnique
I have a similar issue where the ac wouldnt come on. After reflashing and all that jazz, now the compressor will not turn off.
I'm now using a vit tuned hybrid map, and my repair facility ran diagnostics previously and stated everything was ok, and pointed towards the ECU when the ac wouldnt come on. Now I'm scratching my head and have to remove the relay to turn my ac off (good relay).
I tried a generic cal (Fujita SRI, buddy club header, exhaust) and everything works fine. Flash back to stock, AC works fine. Back to my cal, ac does not turn off.
Any ideas?
Posted: Sat Jun 20, 2015 5:25 pm
Try checking 'use second coolant temperature sensor for fan control' (which is the normal behavior).
