emulator
Posted: Thu Mar 11, 2004 11:34 am
by ultrab20
having trouble getting emulator to connect to the laptop... and when we run datalogging it comes up with a bunch of erroe every second.. like 5 or so.... we are using a USB to serial adapter... should we get a rs232 serial ocmcia card?? could that be the problem??
Posted: Thu Mar 11, 2004 12:02 pm
by DaX
Try increasing the allowable errors per second.
Posted: Thu Mar 11, 2004 4:25 pm
by ultrab20
yeh we did that.. and it works... the problem is that the emulator will not connect
Posted: Thu Mar 11, 2004 7:45 pm
by turbosi92
ultrab20 wrote:yeh we did that.. and it works... the problem is that the emulator will not connect
Make sure you have the correct port.
Posted: Fri Mar 12, 2004 1:47 am
by ultrab20
hahah thanks guys..i did all the idiot things... and it still wouldnt connect.. i called hondata and they suggested to get a Keyspan USBtoSerial adapter...well it works/connects fine... NOW the problem we have is that i cannot get the rom editor(emulator) AND THE datalogging to connect at the same time..ughhh fuk DEREK where are you>>> hahah
Posted: Mon Mar 22, 2004 7:49 am
by Carchitect
Connect the Romulator thru the Keyspan USB adapter and datalog directly thru the serial port. Make sure you select different comm ports for both. Try to get into your device manager thru your settings to see which port does what to figure you the port you will be using accordingly.
Joe.
