b18c turbo 60, 440 inj,tunning problem
tonedizzle
tried running the revhard map but runs very poorly. any one have a map i can try with the right calibrations? stock internals,ran great with greddy b16 turbo 240cc map. stock map sensor. running 5lbs boost
jamesfawcett
Re: b18c turbo 60, 440 inj,tunning problem
hey mate, theres my basemap here if you want to try:
440 injectors, t28 turbo, b18c4
http://www.jamesfawcett.co/index.php?op ... &Itemid=19
hope this helps you
hope this helps you
would you mind reposting your map for this application thanks!!! :)
