base map
ultrab20
base map
Post by ultrab20 »
ok, trying to make a base map, for a B18c1 12:1cr skunk2 stage II cams with 310cc rc injectors
when we burn the base map with the 310 injectors, it wont start
when we burn it with the stock map/injector sizing it starts and runs(kinda shitty) but it runs....any ideas? we tried changingthe injector multiplier too.. but no change...>>??
ben
Post by ben »
Maybe the cam timing is causing a low vacuum condition (due to the cams) and the ECU is using inappropriately tuned fuel cells that are giving the motor too much fuel.
