prc kpro in 03 rsx type S with problems
tnxx
Post by tnxx »
I've just got a prc kpro installed on my 03 rsx type S with K24a2 motor but comes across several issues that needed help. 1/ the temperature gauge stops working. It did with the stock prb ecu, but stops working when I installed the prc Kpro. 2/ vss error code comes on while driving. 3/ error code on "vtec malfuntion, oil pressure switch" and won't let me rev pass 4k. If I disable the vtec oil pressure switch, then the car does not have vtec. 4/ The A/C no longer working. The compressor clutch does not engage when the button is pressed.
Can someone help me out here please.
Re: prc kpro in 03 rsx type S with problems
What is the serial number of the K-Pro board inside the ECU and what dealer did you purchase this from?
tnxx
Post by tnxx »
I'd bought it from another person. And the I am not with the car at the moment so i have to get the serial number later this evening. What can you tell me about the problems I am having?
tnxx
Post by tnxx »
any help from hondata?
Spunkster wrote:What is the serial number of the K-Pro board inside the ECU and what dealer did you purchase this from?
tnxx
Post by tnxx »
Serial # 05864
hardware 2.16
I need to know how I can enable vtec and disable vss.
tnxx
Post by tnxx »
The car is 03 rsx type S. with k24a2 swap with bolt on. No internal mods. I used stock k24a2 maps provided from the latest version I'd downloaded. The Ecu is prc based. If I leave the oil pressure switch on then the check engine light comes on and I can't pass 4k rpm. But when I disable it, vtec does not work. And I need to know how to disable the vss error code too.
tnxx
Post by tnxx »
any help?
tnxx
Post by tnxx »
What are you looking for specifically? I've already stated everything that listed in the link.
tnxx
Post by tnxx »
Hondata help is amazing.
You still have not provided the calibration and a datalog showing the problem.
