S300 not reading TPS.
Shortshift
Post by Shortshift »
I have a 95 civic with a LS V-tec. I just bought a S300 Hondata computer. With the S300 the car will only rev to about 2500rpm and then it cuts the fuel. When I plug in a stock computer for an integra the car runs perfectly. They only thing that I can see that is abnormal is that in the datalist it says that the TPS is at 0% all the time. I have replaced the TPS as well as checked all the wiring to it. If someone could give me some ideas or any help at all it would be appreciated.
AREA876
Re: S300 not reading TPS.
Post by AREA876 »
Post calibration and datalog of problem
Try the ECU on a known good vehicle and see if the problem persists. There is a possibility that you have a damaged ECU.
