See anything wrong??? Help
Posted: Sat Jun 25, 2011 10:54 am
by hottopic58
This is the tune I have now and things just don't act right. Any suggestions?
Re: See anything wrong??? Help
Posted: Sun Jun 26, 2011 1:05 pm
by hottopic58
here's a data-log
Posted: Mon Jun 27, 2011 11:14 am
by hpmx18
wats the setup cause that dnt look like i seen before who did that map for you
Posted: Mon Jun 27, 2011 12:44 pm
by hottopic58
I got the base off of here from a guy and then I have just been working with it since then. Doing runs and changing things. Then repeat, etc. It's a built F22b1 8:1 N/A with the hondata heatshield and 310cc inj., walbro 255hp pump,P72 s300, AEM wideband, Block guard. Stock cam, stock cam pos, 16deg. timing
Posted: Mon Jun 27, 2011 12:45 pm
by hottopic58
hpmx18 wrote:wats the setup cause that dnt look like i seen before who did that map for you
What looks weird??
Posted: Mon Jun 27, 2011 4:46 pm
by hpmx18
why not wire the s300 do the o2 pin so you can log a/f in s300 for obd1 its "D14" if its obd2 its "D2" do that and log it again cause you a/f dnt look rite
Posted: Tue Jun 28, 2011 3:11 pm
by hottopic58
hpmx18 wrote:why not wire the s300 do the o2 pin so you can log a/f in s300 for obd1 its "D14" if its obd2 its "D2" do that and log it again cause you a/f dnt look rite
I'll look and see what pin I have it ran to. but all the tables look good and all?
Posted: Tue Jun 28, 2011 4:48 pm
by hpmx18
aight
Posted: Fri Jul 15, 2011 6:15 am
by x6h0ztx
tables are to high for fuel. that will need to be lowered accordingly throttle tip in trim %
