Problems with car .?.?. Help!!!
hottopic58
Post by hottopic58 »
Don't know what's going on but it just skips alot and its intermittent wile I'm driving. Acts like its on rev limiter at any rpm sometimes... Bust all up and the goes??? Any Ideas?? I'm thinking i just need to change the dizzy or coil but idk might be something else idk about. Any help will be appreciated.
Re: Problems with car .?.?. Help!!!
hottopic58
It's a 94 accord with p72 s300. 8:1 heatshield 310cc valves springs and retainers.
hottopic58
here's the data-log
Has this been tuned on the dyno?
hottopic58
no dyno time yet. Just street tuned with the wideband and data logs.
Get it tuned by someone that knows how to properly tune.
hottopic58
so you can't just tell me something wrong with it? I know it needs to goto the dyno but just to have a mild street tune it should run fine. It's been running on this tune for a long time now. I just did know what could have happened. I'm going to check the dizzy and see if the shaft is leaking oil on the rotor button. That might ball that's wrong. But as far as the tune goes It looks bad to you?? Any pointers????
